B234T3 from 1998 v70 t5. but i want the 18t (not 16t) on it. do you mean 1998 V70R? and if i have the AWD but decide to remove driveshaft, will that throw off ECU? ive heard the removal creates less friction and weight, improving performance. do you or anyone yuou know, know if its the turbine or core that im suppose to swap to go from 16t to 18t?Chuck W wrote: β21 Jul 2020, 18:43The B5234T3 is just a basic 2.3 HPT engine. What year are you getting it from? 99-04 B5234T3 has exVVT. (You can just leave it unplugged, if it has it)CIK7 wrote: β21 Jul 2020, 16:49 lol im flaking on the manual swap. the 13g engine is dead. right now im focused on a new engine with fresh parts. im thinking about buying b523t3 engine, replacing 16t with 18t, swapping the blue injectors for white injectors. What ECU would I need with this setup? T5 or R? I dont want to stance it. And i have the V70 T5 wheels on there. Awesome tires too. but with the turbo, which parts do i swap to go from 16t to 18t?
The white and blue injectors are basically the same, no need to swap them in this application.
If you're going to use the 18T and you're AWD you'll probably want a '97 V70R AWD ECU (last 3 digits of -455).
turbo comp chart, core interchangeable? 16t vs 18t vs 19t Topic is solved
- CIK7
- Has thanked: 318 times
- Been thanked: 86 times
Re: turbo model comp chart, core interchangeable? 16t vs 18t vs 19t
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 96 times
- Been thanked: 333 times
1998 V70R AWD with the last 3 of the ECU being -455
It would probably be fine if you run it FWD.
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
You can keep the turbine wheel and lil rusty middle nugget from the 16T. But you'll have to source a compressor wheel and cover for the 18T and those are not easy to find on their own. If you can find an 18T at all, it'll probably be a complete unit. By the time you buy a rebuild kit and get the thing balanced it'll probably cost as much as buying a used turbo. (Source: experience. I built my 16T into a 19T for probably like $500 total, with parts from ARD and a rebuild from a local turbo shop. The day I picked it up from the shop, I saw a freshly built and balanced OEM 19T on eBay for $400.)
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
but if you are meaning to put this motor in an 850 (?) then you can upgrade the turbo to 18 or 19, need to match the flange design, straight versus angled. Look at using an ECU tuned for your application. Bigger turbo and injectors, just a flash to the ECU. You can use one from a similar year HPT 850, or maybe a 98 *70 HPT. Depends on your AC control etc. Or perhaps a canned tune like ARD Green or Blue depending on your mods and what is available (Viva, IPD, EBay) What year and motor is the 850 you are looking at?
Current Volvos:
- CIK7
no i switched gears. unable to find good affordable volvo nearby. going for engine replacement and upgrades at same time. thank you i will ttake lok at tunes. i was told a 98 v70R ecu should work fine.FLXC90 wrote: β21 Jul 2020, 21:09 but if you are meaning to put this motor in an 850 (?) then you can upgrade the turbo to 18 or 19, need to match the flange design, straight versus angled. Look at using an ECU tuned for your application. Bigger turbo and injectors, just a flash to the ECU. You can use one from a similar year HPT 850, or maybe a 98 *70 HPT. Depends on your AC control etc. Or perhaps a canned tune like ARD Green or Blue depending on your mods and what is available (Viva, IPD, EBay) What year and motor is the 850 you are looking at?
- FLXC90
Continue to check on the ECU, seems to me all US 98 Rs had 16Ts on them, went up to 18T for 99 and 19T for 00. 98 Manual Rs got the 18T but that was not over here. But I don't have an R so I can't tell you for sure.
Current Volvos:
- Chuck W
The '98 V70R AWD had a B5234T4 with an 18T.
- CIK7
i wanted the t4 for that reason but im guessing T4 just signifies it as having the 18t. because the t3 has a 16t which is step down from 18t. thats how i come to that conclusion. someone told me the 2.3s are all pretty much the same besides the turbo.
- CIK7
i got your response here around same time i got same response from bmdubya, so both of yoal answered my question. Thank you. yes the 18t housing is nowhere to be found. what if i use the 19t housing with 18t chra?j-dawg wrote: β21 Jul 2020, 20:59 You can keep the turbine wheel and lil rusty middle nugget from the 16T. But you'll have to source a compressor wheel and cover for the 18T and those are not easy to find on their own. If you can find an 18T at all, it'll probably be a complete unit. By the time you buy a rebuild kit and get the thing balanced it'll probably cost as much as buying a used turbo. (Source: experience. I built my 16T into a 19T for probably like $500 total, with parts from ARD and a rebuild from a local turbo shop. The day I picked it up from the shop, I saw a freshly built and balanced OEM 19T on eBay for $400.)
- Has thanked: 292 times
- Been thanked: 765 times
ARD tuning went out of business over a year ago, maybe even two years now.FLXC90 wrote: β21 Jul 2020, 21:09 but if you are meaning to put this motor in an 850 (?) then you can upgrade the turbo to 18 or 19, need to match the flange design, straight versus angled. Look at using an ECU tuned for your application. Bigger turbo and injectors, just a flash to the ECU. You can use one from a similar year HPT 850, or maybe a 98 *70 HPT. Depends on your AC control etc. Or perhaps a canned tune like ARD Green or Blue depending on your mods and what is available (Viva, IPD, EBay) What year and motor is the 850 you are looking at?
All the 2.3 turbo engines 94-98 are the same, don't sweat the numbers at all. For a given year the R designation engine is *exactly* the same as the T5 engine. The turbo is not part of the engine it is a bolt-on accessory. Lots of options for the bolt-ons but the engines are the same and completely interchangeable.
If you're going to go to the trouble of getting a tune, I'd get an LPT engine 95-98 for simplicity. If you want to hassle with modifications the 2.3 RN engines (99+) are probably a better option. Then choose (and/or rebuild) your turbo, then get the appropriate injectors and tune to match. Presumably you're not messing with the exhaust but if you are that factors into the tune.
If you're using an off-the-shelf ECU then pick your ECU first, then get an engine-injectors-turbo that match.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- 2587 Views
Last post by IG-88A
- 25 Replies
- 4187 Views
Last post by shadetree_v70
