2006 V70 wheel fitment
GlennG2759
Year and Model: 2006 V70 NA
Has thanked: 112 times
Been thanked: 17 times
Post by GlennG2759 »
Can anyone tell me if the wheel off a 1996 960 has the same bolt
pattern and offset to fit my 2006 V70?
Thanks,
Glenn
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Pull a wheel off each. Look for the Volvo part number on the back side. Post part numbers.
Active
Past
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
GlennG2759 wrote: 23 Jul 2020, 19:34 Can anyone tell me if the wheel off a 1996 960 has the same bolt
Thanks,
Glenn
It has the same bolt pattern and center bore so it will fit. Offsets look close enough.
https://www.wheel-size.com/size/volvo/960/1996/
https://www.wheel-size.com/size/volvo/v70/2006/
Been thanked: 4065 times
Matt has a pdfdocument if the P80 alloy wheel options and offsets in the VRD
I’ll try link
Bingo
viewtopic.php?f=4&t=59248
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
As for the 960 I don't know which wheels they had, but I have 15in wheels from the S70 on my base non turbo 2003 S60 which came with 15in standard - the lug cone is different on the S70 but my S60 bolts fit well. The thing is the wheels need to clear the front calipers. What is the standard wheel size for your 2006 base S60 ? It's written behind the fuel door
GlennG2759
I have 235/45 17" Thors that were optioned when original owner bought the car. They look great, but too harsh of a ride, I'll need tires to get thru N.Y. Inspection so I'm downsizing to 16". Someone close by has 16" Mercurius wheels with 205/55 Continentals (almost new) off a 1996 960. $200.00. sounds like a deal to me. From looking around it looks like they'll fit, but will probably just pull one off to see if they fit. Thanks for info.
MoVolvos
Post by MoVolvos »
GlennG2759 wrote: 24 Jul 2020, 06:53 I have 235/45 17" Thors that were optioned when original owner bought the car. They look great, but too harsh of a ride, I'll need tires to get thru N.Y. Inspection so I'm downsizing to 16". Someone close by has 16" Mercurius wheels with 205/55 Continentals (almost new) off a 1996 960. $200.00. sounds like a deal to me. From looking around it looks like they'll fit, but will probably just pull one off to see if they fit. Thanks for info.
Our C30 uses 215/45/18. Others have used as large 245/45/18.
Here is the tire calculator. You be surprised what you can get away with size wise. Remember if the tire is 1 in taller it is split half on top and half on the bottom in terms of clearance. The same is true for width.
https://tiresize.com/comparison/
Glenn
I have spares if you need inspection loaners until you find the ones you want Sent pm with details. I have a friendly place up here that inspects while you wait , too.
