please post mvs link to timing belt tensioner VIN thread; unknown if it is hydraulic or mechanical Topic is solved
CIK7
Year and Model: 2026 Sportrailer GLT
Has thanked: 350 times
Been thanked: 108 times
Post by CIK7 »
i dont know if my tb tensioner is hydraulic or mechanical. there are only thousands of threads and responses about timing belt tensioners and as usual i cant find the thread that has the part numbers listed. i believe it goes by VIN code and i want to replace mine before putting new engine in. please help me. i thought it would be in Major Repair topics but so many threads plus repeats.
BTW I just purchased my new 2.3L, I believe before noon. excited!
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
Has thanked: 2199 times
Been thanked: 1851 times
I may be wrong, but I thought that there were only 2 options. Earlier cars up until some random time in 98 with hydraulic tensioner and mechanical tensioners. Maybe I am about to learn something new?!
CIK7
Post by CIK7 »
scot850 wrote: 24 Jul 2020, 17:27 I may be wrong, but I thought that there were only 2 options. Earlier cars up until some random time in 98 with hydraulic tensioner and mechanical tensioners. Maybe I am about to learn something new?!
yes only 2 options but i need to figure out which i have. i didnt specify that at first. thread is updated now. sorry about confusion.
Has thanked: 1609 times
Been thanked: 4065 times
It goes by engine number . Not VIN code
There is a thread with the break I will search for
Your engine number is in a sticker on the timing belt cover , and also stenciled into the block near the water pipe
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
abscate wrote: 24 Jul 2020, 17:35 It goes by engine number . Not VIN code
1998 S70/C70/V70/XC/R:
Hydraulic tensioner engine serial number --- 1266127.
Mechanical tensioner engine serial number 1266128 --- .
Active
Past
amblerman
Year and Model: 1999 s70
Has thanked: 2 times
Been thanked: 70 times
Post by amblerman »
If you take off the top timing cover (The one with the clips), I bet you have enough space to look down and see if there is a mechanical tensioner or not.
if yes, you have one.. if not.. hydraulic (in a different location).
Thesis
If you timing marks are at the top of the timing cover you have mechanic tensioner
If they are at roughly 1330 and 1030 clock positions on the timing cover, you have hydraulic tensioner
If you have VVT, you have mechanical
If you have coil on plug, you have mechanical
CIK7
Post by CIK7 »
abscate wrote: 24 Jul 2020, 17:35 and also stenciled into the block near the water pipe
water pipe (where the thermostat is) or did you mean to say water pump? and 1998 p80s didnt have coil on plug until ford took over i thought. only on 960/sv90.
CIK7
Post by CIK7 »
the tensioner i have is visible by pulling away the front wheel well cover next to crank. im guessing this could be different on my new t5 engine but same year and model (v70)
CIK7 wrote: 24 Jul 2020, 19:33 the tensioner i have is visible by pulling away the front wheel well cover next to crank. im guessing this could be different on my new t5 engine but same year and model (v70)
That’s hydraulic. It’s 10 cm long cylinder where as the mechanical one looks like a pulley
