You need to replace every oring you touch in the system. The condensor can be inspected for physical damage and reused. Drier always gets replaced.
The evaporator usually look like this and need replacement
98 xc ac leak; any part replacement recommendations while cleaning engine bay?
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
friend ordered new evap yesterday eve. ill add drier to my cart.abscate wrote: 24 Jul 2020, 19:47 You need to replace every oring you touch in the system. The condensor can be inspected for physical damage and reused. Drier always gets replaced.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- CIK7
never knew anything about drier, glad you said something. going to look for onescot850 wrote: 24 Jul 2020, 17:23 Of the other replacement parts, drier is #1 to buy. Pointless repairing system and not fitting new drier. There is a recommended time once a system has been repaired that you should fit a new drier otherwise it absorbs a lot of moisture. Aftermarket ones are ok for the most part. Only issues I have had with both the evaporator and drier aftermarket was they would not allow the snap rings to fit as they were either slightly too large or out of round on the ends. Both fixed by careful filing.
Has to be new. The drier has silica gel inside which absorbs mositure
The Volvo mantra for maximum time open for drier replacement is 24 hours
The aftermarket Rein replacement is under $15 from FCP
Rein bRand is good for our cars.
Under $20
Big metal can with two oackets of “do not eat “ Stuff
Under $20
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
Be warned, I had to slightly bend the neck on my rein dryer for a better fitment.
wheelsup
- Year and Model:
- Has thanked: 16 times
- Been thanked: 22 times
Have fun 'bro
I used a harbor freight air powered pump (read: not efficient) and to this day it still works, although my clutch is going slowly even with the added pressure with zip ties.
1995 850 GLT Wagon w/ 200,000 miles
- CIK7
I'm assuming you are just doing maintenance with dash out. This here is my junk car soon to be trailer car. I cut out the giant wire snake that trails underneath the inside of windshield. Also 2 of the mega wiring harnesses. Lolwheelsup wrote: 12 Aug 2020, 21:44 Have fun 'bro
Keep picking at. That, there is a lot of good stuff still on that car...
Once the vultures leave, you are close
- smacknab
- Has thanked: 97 times
- Been thanked: 43 times
My foot vent gets bigger with every passing dayCIK7 wrote: 24 Jul 2020, 15:57hahahahhahahahahahahahahahahaha! rare passenger foot vent XD just stick it down there wont have to worry about a foot vent no more XD jkjk thank you for the info.abscate wrote: 24 Jul 2020, 14:30 Sorry , I don’t know why I wrote that you cam borescope the evap from the air filter. That’s not right.
Here’s how.
Remove glove box liner and lower passenger kick plate.
Remove power transistor
07 V50 T5 AWD M66 ~146k miles
- 1559 Views
Last post by instarx
- 666 Views
Last post by EagleEyecincuenta5
- 25 Replies
- 5694 Views
Last post by jbeebo
- 753 Views
Last post by Andrew Vanis
- 2593 Views
Last post by Phaedrus68
