Good idea. Would it be helpful to arrange in a searchable Excel spreadsheet? Also, it would be good to state the ISO standard -XXX identification number. Expand for P2 Volvos?
( I think I just volunteered to help)
P80 Master O-ring Model Part Number Size Type Comment Thread
- Has thanked: 987 times
- Been thanked: 1075 times
- Been thanked: 4068 times
Part 3545416
Dimensions 17mm x 1.5 mm nominal
Used in pairs on the warm side of evap as well as the return side of drier
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 63 times
- Been thanked: 81 times
@abscate I very much appreciate postings like this and have tried to document similar information a few times myself so that others (and myself) can search it out in the database. What you've done with this o-ring info is actually quite a generous act, both in what you posted and in the other input you will generate.
I don't know how helpful it will be to Volvo owners, but I recently got some o-rings for a water filter system from a company called
Captain O-Ring at www.captainoring.com (I like the name.)
I can second the recommendation about ordering extra 0-rings and crushable washers for thing like the oil plug and banjo connectors. The real trick is being able to find those little parts when you need them. I'm still working on that. Thought I had it solves a couple of times, but no...
All U.S. market models.
All running and on the road.
Turbo and 1999 PCV banjo bolt copper gaskets
Part 11194 - this is also a P2 ECT gasket so if you need one look for a P2 nearby.
Size 18mmx12mm by 1mm thick
Fitment
P2 ECT gasket
P80 Turbo oil line supply (return uses a different drain system with a flat gasket) 2peices total
P80 Coolant turbo supply and return banjo, 4 pieces total
1999 PCV vacuum banjo bolt under IM - 2 pieces
1999 Coolant PCV pipe return to cylinder head at rear of engine, 2 pieces
(Supply uses hose with barbed connector
Fitment
P2 ECT gasket
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
I ordered the santech o-ring seal kit RS2672 for my AC overhaul. Here are the measurements I got with my caliper. OD x ID x Thickness
Zion, do you mind if I screenshot that and cross reference it to part and function?
That will be the ultimate kickass reference tool for P80 AC
Cross reference of AC o rings from amazon attached
- ZionXIX
Go for it. Take my measurements with a grain of salt. Used a harbor freight digital caliper.abscate wrote: 26 Jul 2020, 04:57 Zion, do you mind if I screenshot that and cross reference it to part and function?
Here is the original picture
Ok, incomplete but work in progress
More progress.
Listed function on left.
Total number of each in blue circled by group
- 1435 Views
Last post by tehniemer
- 714 Views
- 637 Views
Last post by wizechatmgr
- 9 Replies
- 222 Views
- 1969 Views
