Compression test results :
#1 90lbs
#2 90lbs
#3 130lbs
#4 130lbs
#5 130lbs
Does this look like a head gasket issue, and maybe why I keep failing on the glove test ?
Failed glove test
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
Those numbers are with the engine cold so I imagine it's a little higher warmed up. I'm leaning toward trying the seafoam treatment first in hopes that it might help before thinking about taking on the head gasket job.
1999 V70 GLT
1999 V70 GLT
- Has thanked: 987 times
- Been thanked: 1075 times
Did you try a small amount of oil in cylinders 1 and 2? This should seal rings if they are bad. You could also do the coolant test for exhaust gases.
- Sveedy
I just put a little Marvel Mystery in #1 and there was no change at all. So she's warming up right now and I will check at warm temp. But I just checked again and there is no smoke what so ever coming out the tail pipe. She just sits there purring....
1999 V70 GLT
1999 V70 GLT
- Sveedy
No change in compression at hot either. But I did notice a sickly sweet smell when I went into the garage, even with the garage door up.
1999 V70 GLT
1999 V70 GLT
I hope you have an alternate vehicle. I see head work in your future.
I would guess rings but if it smells sweet, you need a new gaskeet.
