I'm wondering if the filter on the windshield washer is clogged, the spray is not as powerful as it should be.
Where are the filters located?
I'm seeing leakage from the hood -- how do I remove the hood insulation, just twist the oblong rubbery connectors 90 degrees?
Windshield Washer - weak spray. Filter location?
- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 77 times
- Been thanked: 59 times
Yes, they either just twist and pull out, or squeeze and pullout (there are two types if I recall correctly). Its likely a T-piece failure rather a filter if you're seeing leaks under the insulation.
The filter for the front is located just infront of the pumps, it looks like a smaller old-school fuel filter.
850forum
- Year and Model: 1995 850 turbo wagon
- Been thanked: 6 times
So to get to the pump - you say plural, are there two pumps? -- Probably need to remove the whatzits - the plastic piece - cowling? I do that once in a while to get the organic sludge out. Or are the pumps on the firewall? I've never looked for them.
NEVER OPEN THE HOOD !!!
- Been thanked: 4071 times
Pumps are down in washer tank
850forum
The connector end of the nozzle itself is broken. So I need a new spay nozzle. Anyone got a part number or the official name of that part?
850forum
maybe this for the front:
https://www.volvopartswebstore.com/prod ... 27605.html
different for rear & wipers...
- Has thanked: 2207 times
When I replaced the nozzle on my 2000 V70 I was advised by the dealer mechanics to use the P2 Volvo version as it gives better windshield spray coverage.
850forum
IDPA also says that 1998 cars might have the Old or New style, so one would want to match the style. Doesn't say if the hole will accomodate any style nozzle.
850forum
So in 2020 I replaced the nozzle.
Now in 2022, the front spray is weak, does not reach the windshield. So probably a clogged filter.
One response in this thread says its like a small gas filter, located "in front of the pumps" which are said to be in the tank.
So exactly what do I need to do to get to it to clean it (can it be cleaned? is it just metal mesh?) or replace the filter?
Going out now to start on the loose wiper arm problem...
- 1949 Views
Last post by Rattnalle
- 1370 Views
- 1339 Views
Last post by bmdubya1198
- 1553 Views
Last post by Roger_850T
- 15 Replies
- 8777 Views
Last post by volvolugnut
