Inner front left CV Joint replacement kit? XC90, 2003, 2.5T AWD
JoqJoSain
Year and Model: 2003 XC90
Post by JoqJoSain »
Hello, i have a XC90 2003 2.5T AWD and i'm looking for a CV Joint for the inner front left side.
I've looked in many web-shops but everyone say there isn't a suitable one for me.
I cannot even find a OEM number for the item.
Some shops say that you have to replace the entire CV Axle, due to no OEM number available.
Help please.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
JoqJoSain
Post by JoqJoSain »
Hi oragex, that is though only the boot for the joint.
I'm looking for the CV Joint.
oragex
Post by oragex »
I believe the metal components are not sold separately. Try to ask on this UK forum perhaps for a place to source a quality aftermarket replacement for the whole axle https://www.volvoforums.org.uk/forumdisplay.php?f=19
Been thanked: 504 times
Post by cn90 »
New GKN axles are about US $300-350.
You can always try your local junk yard in Finland...
JoqJoSain
Post by JoqJoSain »
I ordered a "new" cv-axle.
First time changing one, i wonder is there a need to add front differential or gear-box oil after i replace the cv-axle?
In other words, when i remove the cv-axle is there going to be leaking oil?
Post by cn90 »
Re Axle Job...
- ATF only leaks out of P80 cars bc it is open design.
- For P2, the design is different, there is a cup seal, so when you remove the axle, no ATF will leak.
