Has anyone tried another option to the unreliable Volvo hood latch system? I feel like these parts are aging and deteriorating at this point. The last few junkyard ones I've seen are brittle at the little latch arm...
Anybody figured out how to do AeroCatches or Hood Pins? I'm tired of working on them......
Volvo Hood Latches
- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 77 times
- Been thanked: 59 times
There are lots of posts regarding failsafes for getting hoods open with failures. Have a search, you'll find a good number of options.
Hood-pins can be installed on any vehicle though, and the slam panel would be perfect for a mounting location. Or one could easily fab a small bracket from the little pads that the hood rests on.
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
I have also been worried about this, so I looked at the lever on the drivers side latch and thought it should be reachable from underneath.
I was able to lay on the ground and, knowing where that lever was, simply put my arm up there and feel the lever and trip it.
Stupid easy.
Stupid easy.
1999 V70 GLT
1999 V70 GLT
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
look at this thread for example:
viewtopic.php?f=1&t=92045
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Has thanked: 311 times
- Been thanked: 817 times
The forums show plenty of reports of bad cables, but basically nothing regarding a latch going bad and leaving someone with a hood stuck closed. The latches themselves last well.
