In middle of head job and I don't like the looks of my water pipe screws I removed.
Luckily the same part is used to hold the water pump and I have spares
Its a blind hole for the water pipe unlike the water pump, so no sealer required
Gasket 1236119
Bolt 985151
Flange screw M7 10mm hex x 30mm - to be confirmed
man, the internet is full of false stuff
The bolts measure
M7 shank
10 mmHex
Overall length 32mm
thread length/depth is 24mm
You don't need the sealant for the water pipe, it comes on the bolt because it also used on the water pump (Qty7) where you DO need the sealant.
Torque nominal 17 Nm
P80 Cylinder head work water pump and water pipe screws 985151
- Been thanked: 4063 times
- Has thanked: 2196 times
- Been thanked: 1850 times
Hey abscate, can you add a picture of the location of the offending article if you have a chance? For the life of me I can't picture what bolt you are talking about and where it fits.
Thanks for the great info. Appreciate you taking the time to document this kind of stuff for us.
- Has thanked: 311 times
- Been thanked: 817 times
These bolts (firewall side of the head) have to be the absolute worst part of installing the head.
There is a secret. Leave off the last exhaust stud untIl after you fit the gasket and bolts for the water pipe.
Use straight pick to hold top gasket in position, install lower bolt loosely
Remove pick, install upper bolt
The mirror placement
Install the gasket
Install the gasket
Yes, I took this off again to get the pix.
Thatβs Dedication ..... insanity
Heres a picture from Tys threadscot850 wrote: 31 Jul 2020, 11:12 Hey abscate, can you add a picture of the location of the offending article if you have a chance? For the life of me I can't picture what bolt you are talking about and where it fits.
Plan B
You could also glue the gasket to the head with permatex , then thread the bolts without fussing with gasket
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
+1 Always a little bit of silicone on one side of the gasket so it stays in place when head is put back on.abscate wrote: 03 Aug 2020, 05:21 Plan B
I never put any sealant on WP bolts, never had a leak so far. Maybe I'm just lucky.
BMW 540i 2002
S70 Base 2000
- 289 Views
- 5108 Views
Last post by darrylrobert
- 12 Replies
- 3932 Views
Last post by Jonboy74
- 1311 Views
- 17988 Views
