P80 Cylinder head work water pump and water pipe screws 985151
Has thanked: 1609 times
Been thanked: 4065 times
In middle of head job and I don't like the looks of my water pipe screws I removed.
Luckily the same part is used to hold the water pump and I have spares
Its a blind hole for the water pipe unlike the water pump, so no sealer required
Gasket 1236119
Bolt 985151
Flange screw M7 10mm hex x 30mm - to be confirmed
man, the internet is full of false stuff
The bolts measure
M7 shank
10 mmHex
Overall length 32mm
thread length/depth is 24mm
You don't need the sealant for the water pipe, it comes on the bolt because it also used on the water pump (Qty7) where you DO need the sealant.
Torque nominal 17 Nm
Has thanked: 2199 times
Been thanked: 1852 times
Hey abscate, can you add a picture of the location of the offending article if you have a chance? For the life of me I can't picture what bolt you are talking about and where it fits.
Thanks for the great info. Appreciate you taking the time to document this kind of stuff for us.
Has thanked: 311 times
Been thanked: 817 times
These bolts (firewall side of the head) have to be the absolute worst part of installing the head.
There is a secret. Leave off the last exhaust stud untIl after you fit the gasket and bolts for the water pipe.
Use straight pick to hold top gasket in position, install lower bolt loosely
Remove pick, install upper bolt
πŸ˜€
Tools used. Extra points for finding the monkey in the picture
The mirror placement
Position the mirror thusly
Install the gasket
With the stud out, you caN easily ease the gasket in until you see the hole align
Beautiful ....
Beautiful ....
Yes, I took this off again to get the pix.
That’s Dedication ..... insanity
scot850 wrote: 31 Jul 2020, 11:12 Hey abscate, can you add a picture of the location of the offending article if you have a chance? For the life of me I can't picture what bolt you are talking about and where it fits.
Heres a picture from Tys thread
Plan B
You could also glue the gasket to the head with permatex , then thread the bolts without fussing with gasket
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
abscate wrote: 03 Aug 2020, 05:21 Plan B
+1 Always a little bit of silicone on one side of the gasket so it stays in place when head is put back on.
I never put any sealant on WP bolts, never had a leak so far. Maybe I'm just lucky.
BMW 540i 2002
S70 Base 2000
