ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
RickHaleParker wrote: 04 Aug 2020, 21:34
ZionXIX wrote: 04 Aug 2020, 15:01 Does anyone know what the residual capacity for coolant is on the P80 turbo engines? The total capacity is listed as 7 liters. I want to switch coolant types and I'm planning to do a system drain and fill with distilled water. Would the remaining water affect the the new 50/50 mix?
If you flushed it with water the residual capacity does not matter. You add 3.5L of undulated antifreeze them top off with distilled water (Not to distilled drinking water) get 50/50.
My biggest concern is: if you used tap water to flush the coolant system. Tap water can contain Minerials that can leach out and coat the walls of the coolant system. Lowering the coolant system thermal conductivity. Hindering the coolant system's ability to transfer heat.
I bought several gallons of distilled water just for the occasion. I already purchased 50/50 prediluted since local parts store did not have concentrate in stock. I think a little less than 50/50 in the end should be fine with a change out at the next oil change. Just wanted other opinions.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
ZionXIX wrote: 04 Aug 2020, 21:47 I bought several gallons of distilled water just for the occasion. I already purchased 50/50 prediluted since local parts store did not have concentrate in stock. I think a little less than 50/50 in the end should be fine with a change out at the next oil change. Just wanted other opinions.
I suggest you go ahead and top off with the premix. Use a Antifreeze test strip to measure the concentration. If you need higher concentration. Acquire some undulated antifreeze before winter and make adjustments.
Active
Past
Has thanked: 1613 times
Been thanked: 4075 times
The residual in the system after dumping just from the radiator stop cock is substantial, like 3-4 liters
That’s why the preferred method is to flush with water, drain and add 4 liters concentrate after closing the stopcock.
You will have to use compressed air and hoses to get the residual water out.
There is also another drain cock on the water pipe on the right side of motor, toward rear of car on the water pipe, probably best reached from below. I’ve cracked one of these on an engine as I was always scared it would break off and leave a nasty job. It is very high quality brass fitting and it released easily
ZionXIX
Post by ZionXIX »
3-4 liters is an insane amount of residual capacity. None of my local stores stock the concentrate so I'll have to put the green stuff in that I already have on hand and do a change out later.
brunocerous
Year and Model: 1998 V70
Has thanked: 303 times
Been thanked: 43 times
Post by brunocerous »
Last weekend, with temperatures near 90 degrees, I drove home the '98 T5 with the kids because it's the only P80 I have with air conditioning, I swapped in a new AGM battery to replace the old one that kept dying — and now it doesn't start anymore. I just get a click/sproing sound when I try to crank it.
My brother says it's likely the antenna ring, so it looks like I'll be swapping it out this afternoon.
Could it be something else? Bad starter? AGM battery?
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
amblerman
Year and Model: 1999 s70
Has thanked: 2 times
Been thanked: 70 times
Post by amblerman »
ZionXIX wrote: 05 Aug 2020, 06:31 3-4 liters is an insane amount of residual capacity. None of my local stores stock the concentrate so I'll have to put the green stuff in that I already have on hand and do a change out later.
What kind of coolant type do you want switch to?
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
brunocerous wrote: 05 Aug 2020, 08:21 Last weekend, with temperatures near 90 degrees, I drove home the '98 T5 with the kids because it's the only P80 I have with air conditioning, I swapped in a new AGM battery to replace the old one that kept dying — and now it doesn't start anymore. I just get a click/sproing sound when I try to crank it.
I don't think the '98 has an antenna ring, and if so, it will crank, but not start.
So does it try to crank, or does it crank and not start?
Yeah , even Dr Brothers have their limitations.
No crank is ignition switch, wiring , or clutch switch on the M56
Go find the remote starter bypass and confirm your battery , starter, and main cables are all sound
Chock it, triple check in neutral, and parking brake firmly on when you use the bypass
ZionXIX
Post by ZionXIX »
amblerman wrote: 05 Aug 2020, 08:29
Zerex G48
brunocerous
bmdubya1198 wrote: 05 Aug 2020, 09:10
It just makes a sound that's somewhere between a 'click' and 'sproing' when I try to crank it.
I'd never had any problem starting it before, but something similar did happen with the '99 XC V70.
