P80 hydraulic tensioner detail 9135036
Has thanked: 1611 times
Been thanked: 4075 times
I had a mechanical tensioner moment and undid the nut on the hydraulic tensioner in Earl
I think I just need to remove the whole thing to counterhold and tighten the tensioner axial nut again
See pic...the detail isn’t given there
Hmmm, doesn’t like my pic
Yikes. 19 and 19 A showing as NLA at Volvo web store? ( update, orderable at FCP)
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 63 times
Been thanked: 81 times
Post by Eddystone »
Abscate or anyone else, does anyone have a VIN sequence showing whether your car has the hydraulic or mechanical tensioner without having to do any disassembly to check?
All U.S. market models.
All running and on the road.
Has thanked: 312 times
Been thanked: 818 times
Hydraulic, from FCP: Up To Engine Serial Number -1266127 (See Sticker on Timing Cover) https://www.fcpeuro.com/products/volvo- ... 70-9146693
Mechanical, from FCP: For vehicles with mechanical tensioner and direct ignition, engine range from 1266128 up to 3192745, https://www.fcpeuro.com/products/volvo- ... e-30638277
This is a hydraulic tensioner.
I undid the wrong bolt , the one in the actual rotating part , and can’t tighten it now
I tried to remove the T45 holding the assembly on and couldn’t move it.
Sigh.
So you can't get the T45 to budge? Is this engine in the car?
Yes,
Here’s a pic from an engine that’s out, sorry for blur, Iphone camera is dying
I took the pulley nut off, and now can’t counterhold whatever is on the back
I’ll either have to get that T45 out or take off the timing cover and wheel the pulley around to the front to get at it
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
The Rolling Stones made a hit for this situation - Can't get no satisfaction.
I need a short, strong T45 bit to solve this removal.
Found a picture at FCP showing the counter hold need
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
This doesn't look fun. I hope those knuckles are okay!
Retired:
2015 Volvo S60, T5, 85K
