Hi folks,
I've been a lurker on these forums for the last few months and I've encountered a problem on my 850R that I can't wrap my head around.
I'm getting a P0171 code but my LTFT reads -25. I've pulled the spark plugs from the car to check and they were black and smelled like fuel. I'm just not sure how I get a lean code, but I'm running extremely rich.
My STFT is all over the place and I can't seem to pin any sort of pattern. I did notice recently that when I accelerate my STFT goes rich very quickly.
Boost gets up to 10psi but I do feel acceleration isn't quite as snappy as I'd expect it to be.
Overall, the car starts up fine and drives without much issue.
I've included a list of mods that I have currently and the steps I've taken to try and address the issue. I've also included a freeze-frame based on the results of my scanner.
I plan on doing a compression test, but not entirely sure how relevant it might be.
Any help would be appreciated, as I'd like to get this running right and fix this code once and for all.
Problem Solving Steps
Intake manifold gasket
Checked vacuum lines
Upgraded intake hoses, and rechecked connections
Upgraded vac lines, rechecked connections (vacuum gauge reads between 16 to 20)
New coolant hoses
New plugs and coils
New front and rear O2 Sensors
General Maintenance
PNP Switch
Water Pump
Timing Belt
Oil Dipstick Seal
Transmission Dipstick Seal
Oil Filler Cap Gasket
Thermostat
ETC
Serpentine Belt
Heater Hose Junction Replacement
Oil Cooler Gasket
PCV
Intake Manifold Gasket
New battery
Mods
19T Turbo
Do88 Intercooler
Do88 RIP Kit
Green Injectors
VAST Tuning Base Tune
IPD Downpipe and Exhaust
IPD Transmission Cooler
Walbro Fuel Pump
Lean Code P0171, but LTFT is -25
- RickHaleParker
- Been thanked: 980 times
Leak in the exhaust system.zrjn89 wrote: 06 Aug 2020, 22:37 I'm getting a P0171 code but my LTFT reads -25. I've pulled the spark plugs from the car to check and they were black and smelled like fuel. I'm just not sure how I get a lean code, but I'm running extremely rich.
1. Air gets sucked into the exhaust.
2. O2 sensor detects the unburned oxygen.
3. ECM interprets it as too lean, dumps more fuel in the cylinder to compensate.
4. Extra fuel does not burn because there is not enough oxygen in the cylinder.
Active
Past
Past
bronco
- Year and Model: 1998 V70
- Has thanked: 49 times
- Been thanked: 24 times
If you can see the gasket you could try waving a plumbers torch at it. See if the scanner reads the ecm adjust the fuel trim.
i mean it works for intake gaskets ........... Exhaust it might not.
- RickHaleParker
Find the leak before you start changing parts. Try using your ears and eyes first. You might plug the tail pipe start the engine then use your eyes and ears. The back pressure will shoot out the leak.zrjn89 wrote: 07 Aug 2020, 10:51 This makes sense, should I just replace the exhaust manifold gasket? The downpipe, and the exhaust look to be in great condition.
Smoke test the exhaust system. Plug and inject smoke up the tail pipe or plug tail pipe then inject smoke into a O2 port.
Here a neat DIY idea if you have a air compressor.
Active
Past
Past
- RickHaleParker
Should work on the Exhaust side if the torch is lit. When the lit torch is on a leak, the flame will consume the oxygen. No oxygen getting in to the Exhaust the reading should change.bronco wrote: 07 Aug 2020, 12:05
I mean it works for intake gaskets ........... Exhaust it might not.
Active
Past
Past
bronco
i was thinking unlit it might draw in propane and richen the exhaust . Actually , propane directly into the intake with or without an exhaust leak should show up on STFT too I'd thinkRickHaleParker wrote: 07 Aug 2020, 17:45Should work on the Exhaust side if the torch is lit. When the lit torch is on a leak, the flame will consume the oxygen. No oxygen getting in to the Exhaust the reading should change.bronco wrote: 07 Aug 2020, 12:05
- RickHaleParker
Spray a flammable on a hot exhaust?bronco wrote: 07 Aug 2020, 20:42 i was thinking unlit it might draw in propane and richen the exhaust .
Active
Past
Past
bronco
RickHaleParker wrote: 07 Aug 2020, 21:11Spray a flammable on a hot exhaust?bronco wrote: 07 Aug 2020, 20:42 i was thinking unlit it might draw in propane and richen the exhaust .![]()
If it did anything it would only light the torch ? Anyway , don't say "spray" say "waft, gently"
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Have you checked intercooler and the connector hoses? The negative numbers indicate taking fuel away. I would expect the rich P code but scan tools do make mistakes. The black plugs back up the negative numbers from the ECM dialing down injector open time. What is fuel pressure? Is fuel pressure regulator leaking fuel through its manifold sense hose (vaccum hose)?
- 1967 Views
Last post by zmaller
- 5370 Views
Last post by mrbrian200
- 13 Replies
- 4916 Views
Last post by Sandawgk5
- 2535 Views
Last post by chrism
- 9220 Views
Last post by zippy83
