I replaced the 3 lower motor mounts today, not a bad job, took about 4 hours working slowly and tripping over dogs in the garage. The right mount was pretty bad, the other two hydraulic mounts looked ok but the front one was separated as shown in the picture. The rear mount was a little tricky to get at the bottom bolt and then I partially stripped the threads putting the bolt in the new one, had to take it out and run a thread chaser and put it back in.
All three mounts were Volvo and assumed to be original.
Motor mounts after 275000 Kms.
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
2003 XC 70 (sold)
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The one under the crank pulley goes bad quite often, more so if the subframe is lowered for sm reason
Were the main mounts liquid filled ? On diesel engines these are actually vacuum mounts and regular wear item
- Blacklab467
The one under the crank pulley was oil soaked and the rubber was separated from the metal. I’m not sure if the other two were liquid filled, I’ll poke a hole in one tomorrow and see. The front one was almost 3/4 separated!
2003 XC 70 (sold)
- 1436 Views
- 947 Views
Last post by TimothyJ
- 9 Replies
- 2034 Views
Last post by charleskennedy23
- 1340 Views
Last post by sleddriver
- 682 Views
Last post by GlennG2759
