On initial start in the morning the car stumps and stalls. After a few starts it eventually idles normally with no problems. No CEL. I just put a fuel system cleaner in to see if this resolves issue. New Volvo plugs, breather box and air filter have already been done.
Any other thoughts.
Madness
s60 2006 t5 baffled
volvomadness
- Year and Model: v70 2003
- Been thanked: 9 times
- SuperHerman
- Been thanked: 207 times
On start up, when it is lumpy - what does the exhaust look like?
- 2000c70hpt
- Year and Model: 2000 C70
- Been thanked: 8 times
Could be a bad MAF. My c70 did the same thing till I changed it
2000 C70 hpt with 140k
2008 xc90 t6 non turbo with 170k
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The kind of issue you would need to read the codes
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
Mine did that when the fuel pump was on it’s way out. No CEL.
2003 XC 70 (sold)
volvomadness
Thanks all for your replies. Finally I got a CEL and the culprit was the exhaust vvt solenoid. Replaced which solved the constant stalling a power loss issue. Lucky I had spare parts lying around and didn't have to purchase one.
Still have a slight stall when cold on startup no cel. I feel it's the fuel pressure sensor which I will replace this weekend.
Thanks again Madness
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
your lucky, i drove my xc70 for 3 years with a bad VVT solenoid no CEL. Check your key antenna ring, the solder joints can crack causing the car to hesitate to start.Good luck
2001 XC70 factory M58
2002 XC70 auto (parts car)
- 596 Views
- 943 Views
- 850 Views
Last post by MDK
- 30 Replies
- 7693 Views
Last post by Bridge2Fairway
- 2701 Views
Last post by MDK
