I totally agree, though it wasn’t my choice. I bought the vehicle at 178k. My c70 has gone through three plug changes in 20k. Coils failing and whatnot.pgill wrote: ↑25 Jul 2020, 19:31200c70hpt,2000c70hpt wrote: ↑25 Jul 2020, 16:29 Mine had the original FoMoCo plugs in mine after 180k. Xc90 still ran smooth as silk even with those old plugs. Threw some denso iridium in and she livened up a bit. Fuel milage is better though. I used the stock gap
180,000 on the original spark-plugs.......that's a really long way to go
I will be on my fourth set by the time I get to that many miles.
3.2L: What non-OEM plugs do you like or have success with?
- 2000c70hpt
- Year and Model: 2000 C70
- Been thanked: 8 times
Re: 3.2L: What non-OEM plugs do you like or have success with?
2000 C70 hpt with 140k
2008 xc90 t6 non turbo with 170k
- 2000c70hpt
Update to the Denson plugs. About 1000 miles in and i noticed the intake sounds are louder, pulled harder and there is a bit of vibration at idle now
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 115 times
- Been thanked: 185 times
That's what happens when you start fixing things.........2000c70hpt wrote: ↑07 Aug 2020, 10:39 Update to the Denson plugs. About 1000 miles in and i noticed the intake sounds are louder, pulled harder and there is a bit of vibration at idle now
Now you are sensitive to the running of the 3.2
If your going to keep it running until 300,000 mile you will need to do some preventative maintenance.
Good luck
I plan on keeping my S80 3.2 about that long
And my LR2 3.2 (same engine) for that long as well
Which Denso Iridium plugs did you get? Did you get the TT's?
Take care
Paul
- 2000c70hpt
I honestly don't remember. They cost $8 so.. I did notice the upper torque mount is loose so maybe it's time to change it
- pgill
No worries
You can check which plugs you used in 50,000 mile when you change them again (at least that's what I'm doing)
The motor mounts on the P2 (XC90) are different than the P3 (S80) but for what its worth I did change my motor mounts
Good Luck
Paul
Good Luck
Paul
chitownV
- Year and Model: 2008 XC90 3.2
- Has thanked: 15 times
- Been thanked: 40 times
I used aftermarket plugs before, but the increased vibration on idle is why I use Volvo packaged plugs. I got a smoother idle after switching to the Volvo plugs which I believe are the NGKs for my 2008. All the NGKs and Densos have a copper core. Buy from FCP and only pay once.2000c70hpt wrote: ↑07 Aug 2020, 10:39 Update to the Denson plugs. About 1000 miles in and i noticed the intake sounds are louder, pulled harder and there is a bit of vibration at idle now
I found a much much greater benefit in changing all the ignition coils at my 152k miles in both performance and smoother idle. You can try to conduct ignition spark with different accepted configurations of plugs, but nothing beats starting from the source with a good strong spark from fresh coils. Again, I pay once and in another 100k miles or so I'll warranty these at FCP. Doesn't make sense to wait until 300k miles for new coils. New spark plugs cannot replace weaker spark from old and worn coils.
2008 XC90 3.2 AWD - 169k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Continental CrossContact LX25 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
- 2000c70hpt
Honestly not worried about it. Fuel mileage hasn’t dropped, and I’m used to it from my c70 so
- pgill
The 3.2 has some known failure points and you will want to get out in front of them.
I wrote this on another forum but I think you will find it helpful
Quote "The way that I think about it is this.
- The Thermostat is a known failure point at ~10 years
- Failed Thermostats can lead to coil pack failures
- Failed coil packs can lead to misfires and Catalytic converter failures
- And in severe instances a failed Thermostat (or possibly failed radiator fan) can lead to head gasket failure
For me it is easier to just replace the Thermostat and the Radiator Fan."
Here is a link to common failure points on the 3.2
https://www.freel2.com/forum/topic32504.html
And here is an excellent link that talks about the Good Bad and the Ugly (Read what ChitownV wrote, its excellent)
https://forums.swedespeed.com/showthrea ... d-the-ugly
The 3.2 is complicated and very durable if maintained
Good luck
Paul
Good luck
Paul
jpbrooks81
- Year and Model: 2011 XC90
I just got these same plugs in the mail today for my 2011 XC90 3.2. I have been searching all over the webs trying to find out the gap size for my vehicle. Searched through my owner's manual and even managed to access information from VIDA, but there is still no mention of the spark plug gap specs.
These are the plugs that Volvo has listed for my vehicle. I checked the gap and it is 1mm. On the reverse side of my gap tool, it is about .039" - just shy of .04". I'm hoping someone can confirm if this is the correct gap for my vehicle. Thanks!
- pgill
Confirmed...........you are good to go!!!!!
The answer to your question is in the part number
FK20HQR10 10 = 1.0 mm (.040" which is what you measured)
I would use these as is and not attempt to adjust the gap
For reference
FK20HR11 11 = 1.1 mm (.044" these would work also)
FK20HQR8 8 = 0.8 mm (.032" these would work as well)
The sparkplugs that you bought are an excellent choice an I wouldn't hesistate to use them in either of my 3.2's
I am running
.044" Gap on my 2008 3.2 (LR2)
.044" Gap on my 2010 3.2 (S80)
For my next change I am going to .040" Gap
3459 FK20HQR10 (.040" Gap)
or
4704 IKH20TT (.040" Gap but the part number doesn't tell you, you have to look it up)
Take care
Paul
For reference
I am running
or
Take care
Paul
