wipers running very slow on all speeds
zupta82
Year and Model: 1995 960
Post by zupta82 »
I went to use my wipers today and their really slow. It seems their slow on all speeds. I’m guessing it’s maybe a relay that controls the speeds, like a blower resistor. I have a 1997 Volvo 850
zupta82
Post by zupta82 »
Oh, I forgot to mention the arms feel tight and with no slop
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
zupta82
Post by zupta82 »
Hello, I went ahead and took the wiper transmission apart and found one of the shafts completely siezed. I had to hammer out the shafts with a punch. I lubed them with antisieze and grease and the shafts work perfectly. Now I got another problem I can’t get the connecting arms to sync properly.
I marked the shaft on the motor to the bracket before I took everything apart and the wipers were in the park position. When I loosened the nut on the motor it did rotate the motor maybe a quarter turn at the most. Here are some pics
zupta82
Post by zupta82 »
One of the wiper linkage arms seems to be hitting the fusebox
Has thanked: 2212 times
Been thanked: 1853 times
Not a great picture but does this help?
https://www.b-parts.com/en/store/produc ... 1996-1997/
Maybe enough detail to get the correct positions.
Then of course this may help too:
Thanks Robert!,
Has thanked: 1613 times
Been thanked: 4075 times
Worst case run up the street to Erie VOVo and get a used one!
Greeting from an hour East in Albany, the den of Thieves.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
zupta82 wrote: 11 Aug 2020, 20:13 One of the wiper linkage arms seems to be hitting the fusebox
Check the bearing mounts and rod bushings. They can break, crack and wear out.
Active
Past
