05 XC70 Text Message Window out
Faust
- Year and Model: xc70 2008
- Has thanked: 31 times
- Been thanked: 10 times
A little problem with my, new to me, '05 XC70. I have the yellow triangle, exclamation point warning light on. But, the text message window is completely on the blink. Initially I get visual "static" displayed, it then settles to a bright green screen. No text. Any hints? After a minute or two operation the warning triangle light goes out.
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
I would want to see what Vida codes say, at a wild guess its saying the alarm system needs service because the battery in the alarm module has expired. Does the alarm system work? if you set it and open the door does the alarm sound?Faust wrote: 08 Aug 2020, 20:38 A little problem with my, new to me, '05 XC70. I have the yellow triangle, exclamation point warning light on. But, the text message window is completely on the blink. Initially I get visual "static" displayed, it then settles to a bright green screen. No text. Any hints? After a minute or two operation the warning triangle light goes out.
The driver information module (DIM) being out might be unrelated, I think thats controlled by the CEM under the dash, not sure.
Faust
Thank you for your suggestion on VIDA. However poorly stated the intended thrust of my question was recovery, or replacement, of the text message window.
2004 V70
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
DIM needs a repair. Google "Volvo DIM repair service", there are plenty of cheap'ish options on ebay. Or there's XeMoDeX that can take care of your wallet.
Orange triangle can be anything from service reminder to stored codes.
Faust
I have perfectly good dashboard in my '04 V70. Mileage is practically the same. Can I just swap it without "re-programming"? (Not sure tranny position read out would be the same)
2004 V70
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
DIM swaps are difficult, ive read even if the codes part numbers match they can sometimes not work. I have a spare with matching numbers, because of the high failure rate, im still yet to test it.
2001 XC70 factory M58
2002 XC70 auto (parts car)
Faust
Can't explain it. Working on the larger problem of no high beams, I replaced the multi function switch. Now I have a working DIM, but still no high beams.
2004 V70
Faust
Here we go again. As mentioned when I changed my combination switch over the headlight problem the DIM recovered itself. Drove to see a friend to discuss headlight problem, DIM worked fine. While at friends we played with the lights. When I left DIM was gone. Does anyone see a connection? Probably should mention switch is for 05 and 06 only with "trip computer". It is "obsolete", so I went to a junkyard to obtain one. Had pull them from 5 different XC70's to find one with matching part number. Those with a differing part number, do not cure the DIM, nor do they give rise to the blue high beam indicator light on dash.
2004 V70
Faust
As I had the DIM working for 1/2 an hour, it gave the message that washer fluid was low. DIM no longer working.jonesg wrote: 10 Aug 2020, 07:20 in the meantime a $20 bluetooth code reader that works with your phone will probably tell you what the orange triangle is alerting.
2004 V70
- 10472 Views
Last post by natural4reelz
- 11470 Views
Last post by precopster
- 3275 Views
Last post by loveMy850
- 9 Replies
- 7760 Views
Last post by erikv11
- 16 Replies
- 4317 Views
