Throttle Body Cleaning
How To Clean Volvo Throttle Body
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
Is it safe to say that if the TB is gummy there may be a sludge problem elsewhere?
- callahanoffroad
- Year and Model: 1995 850
- Has thanked: 16 times
- Been thanked: 53 times
It's typically just blow by from the pcv system. Potentially it could also be oil from the turbo. Or oil from the crankcase. Give it a scrub, then check your PCV system and your turbo (if you have one).850oldschool wrote: 09 Aug 2020, 14:13 Is it safe to say that if the TB is gummy there may be a sludge problem elsewhere?
- Been thanked: 4069 times
You are typically supposed to clean TB and PCV on 50,000 mile intervals.
It’s normal to get oil residue in the hoses and TB especially on a turbo
- FLXC90
- Year and Model: 98 V70 T5
To remove the cable, using one hand, spin the throttle quadrant (pulley like thing) towards the windshield, with your other hand, guide the cable off to align with the slot in the side of the quadrant, and pop it out.
Current Volvos:
You can unclip the rod that couples the accelerator cable to the throttle body, loosen the Four M6 10mm hex head screws and remove it fir cleaning.
Disconnect the electrical connector if needed.
You will need a new throttle body gasket, too
- Has thanked: 311 times
- Been thanked: 817 times
A gummy TB gives no reason to suspect a sludge problem. Clean it up. Be sure not to get solvent into the TPS.850oldschool wrote: 09 Aug 2020, 14:13 Is it safe to say that if the TB is gummy there may be a sludge problem elsewhere?
- 8813 Views
Last post by MadeInJapan
- 1429 Views
Last post by 800artfreed
- 37 Replies
- 37653 Views
Last post by chitownV
- 2107 Views
Last post by enriquepr21
- 1239 Views
