Hello,
When it is above about 80 degrees F, my 2000 Volvo v70xc won’t down shift from 4th to 3rd up hills and the engine will get bogged down. If I come to a stop, it will shift up through all the gears perfectly fine. Just seems to be that 4th to 3rd downshift. As soon as I come into the city and the temp dips below 70F, there are no issues. Also important is that I can manually put it from 4th to 3rd just fine. Any idea what this could be?
4th to 3rd downshift trouble for Volvo V70XC 2000
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Is yours a 5-speed auto?
Current Volvos:
Sounds like a sticky solenoid. Definitely worth a series of three drain and fills of correct ATF to see if it will unstick
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
How many miles?
As abscate suggested, if you haven't already done so, do several drain & fills with some good ATF (it's a bit pricey ~$10 quart, but I recommend Mobil 1 Syn ATF). When you drop the drain plug, it dumps about 3.5 quarts. Replace the same amount that came out thru the ATF dipstick. Do some driving, and then maybe another drain and fill. After the first one, I would also disconnect the battery for a bit and try to get the transmission learning to reset.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
Richard99
- Has thanked: 26 times
- Been thanked: 23 times
Hi Ed,
Mine has 128k miles. I have done a thorough drain and fill a few months back. I installed an oil cooler from a C70 that I thought would be useful for the heat and hills in CA. Not sure if that has caused anyone problems or not.
Eric
1998 Volvo V70 - rear-ended and totaled
2000 Volvo V70XC
2007 Volvo V50 T5 AWD M66
2000 Volvo V70XC
- FLXC90
You are referring to an aux trans cooler? Like Abscate said, sounds like a sticky solenoid, try adding a trans flush additive, running for a few days, then doing a pump and dump servicing. The main cause and effect I would see in the cooler and your situation is if there were gunk in the cooler that broke free and got into your system. Your mileage and the robust nature of the trans wouldn't normally indicate, especially if you previously changed the fluid by drain and fill. Had it been power flushed then yes. But not by a gravity or self pumping routine. Also, the solenoids are an electronic item (electric really) and they can be fickle. You draw a correlation between ambient temps and the issue, a hydromechanical problem or many intermittent internal electrical gremlins would more likely be fluid temp related. Were the addition of the cooler and the onset of the problem near in time? Also, did you add the cooler to the system, or did you re-route the flow, bypassing the cooler in the radiator.Richard99 wrote: 12 Aug 2020, 00:16 Hi Ed,
Current Volvos:
Richard99
Yes, I installed an aux trans cooler from a C70. When I bought the car about 6 months ago, the owner sold it to me for cheap because it had a hydraulic solenoid fault. I did a pump and dump service to it, as you mentioned and the problem went away. I installed the aux cooler a few months back. I added the cooler to the system, keeping the flow through the radiator. I'm guessing that the problem that I originally had when I purchased the vehicle is creeping back up on me. I'll do another drain and fill to see if that can fix it. Like you said, maybe something from the cooler or residual bad oil is making it act up again.FLXC90 wrote: 12 Aug 2020, 15:40You are referring to an aux trans cooler? Like Abscate said, sounds like a sticky solenoid, try adding a trans flush additive, running for a few days, then doing a pump and dump servicing. The main cause and effect I would see in the cooler and your situation is if there were gunk in the cooler that broke free and got into your system. Your mileage and the robust nature of the trans wouldn't normally indicate, especially if you previously changed the fluid by drain and fill. Had it been power flushed then yes. But not by a gravity or self pumping routine. Also, the solenoids are an electronic item (electric really) and they can be fickle. You draw a correlation between ambient temps and the issue, a hydromechanical problem or many intermittent internal electrical gremlins would more likely be fluid temp related. Were the addition of the cooler and the onset of the problem near in time? Also, did you add the cooler to the system, or did you re-route the flow, bypassing the cooler in the radiator.Richard99 wrote: 12 Aug 2020, 00:16 Hi Ed,
Eric
2000 Volvo V70XC
2000 Volvo V70XC
- 643 Views
Last post by samjaynz
- 2541 Views
- 871 Views
Last post by polskamafia mjl
- 399 Views
Last post by gswede
- 639 Views
Last post by chexny
