Longer crank times
brunocerous
Year and Model: 1998 V70
Has thanked: 303 times
Been thanked: 43 times
Post by brunocerous »
I’ve noticed that our 2004 XC90 AWD has been taking longer to crank lately, up to nearly 3 seconds after turning the key. By comparison, my ‘98 T5 starts immediately.
Is there something I should be checking? Thanks in advance.
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Turn key on, wait 10 seconds then start. Make a difference?
Active
Past
brunocerous
Just tried this, and it still takes just as long.
Could it be the fuel pump? Coils?
RickHaleParker
Any DTCs ?
Active
Past
Has thanked: 1611 times
Been thanked: 4075 times
I will throw the fuel pressure gauge in on the next 'deliver the broken engine hoist arm" trip to NJ
brunocerous
RickHaleParker wrote: 11 Aug 2020, 17:01 Any DTCs ?
The P0441 EVAP code recently came up — in the past week or so — but it always took a little extra time to start up.
brunocerous
abscate wrote: 12 Aug 2020, 10:03 I will throw the fuel pressure gauge in on the next 'deliver the broken engine hoist arm" trip to NJ
Oh, wow. That would be amazing!
I guess it can't hurt to swap out the fuel filter in the meantime.
RickHaleParker
brunocerous wrote: 12 Aug 2020, 15:11 I guess it can't hurt to swap out the fuel filter in the meantime.
The maintenance interval is ten years / 60,000 miles. Is it due?
Active
Past
brunocerous
Good to know! We bought it a year ago with 80k miles on it. Fingers crossed that a new fuel filter will help. Anything else I should look to swap out?
RickHaleParker wrote: 12 Aug 2020, 15:25
Hold off on that fuel filter swap. It seldom helps and you can break the fittings which get you into a rabbit hole.
I’ve opened them up at 100k and found them pristine.
Look here
viewtopic.php?f=1&t=81233&p=439402#p439402
The diagnostic is fuel pressure at rail. If you don’t want to wait ( maybe next weekend?) you can buy a throwaway pencil tire pressure gauge and measure it that way. ( you throw it away because itsfull of gas)
