I just changed all the pads and rotors and cleaned and lubed the caliper pins, now my brake pedal feels mushy and goes almost to the floor and the brakes feel like they have no power. I had to depress the caliper piston to get the new pads in and I did so with the master cylinder cover off. It feels like the brake pedal wants to go to the floor with very weak braking.
I can hear the pump when I step on the brake pedal so I think that is fine. I didn't touch anything else.
I will get some DOT 4 and bleed them but this seems really odd as I didn't open the hydraulic system.
Could it be that compressing the piston and pushing fluid back in the caliper did something weird? I've done a hundred brake jobs and never had this happen! Any Ideas?
Thanks.
New Brakes......mushy pedal
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 114 times
- Been thanked: 263 times
- SuperHerman
- Been thanked: 207 times
Do you have the right pads fitted? Any leaks? Did you damage any of the brake lines (I would suspect a leak). Double check your work, but it sounds like you did it right.
Thinking maybe the piston is frozen, but you should still have a firm pedal. If you have a helper have him/her push the brakes and watch for movement on both sides. Maybe pushing the piston in created an air pocket, but that doesn't make sense. Bleeding the brakes would should solve this.
What was the fluid level in the reservoir when you started and when you finished? It should have been slightly higher when you were done.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Look through the wheel
- Blacklab467
Yep! That 's what I did. How embarrassing! I was in a hurry yesterday doing the brakes and put one of the caliper springs on wrong.
I did find another common problem while doing the back brakes in that my emergency brake shoes delaminated and there was no friction material left on the shoes. I'll have to order some of those and install them another time. Thanks Oragex! I love this forum.
2003 XC 70 (sold)
- - Pete -
- Has thanked: 80 times
- Been thanked: 175 times
If you repair your parking brake, I’d encourage you to shop for new expanders/actuators as well as shoes & springs. You should be able to get a whole kit. The expanders tend to rust to the point their hinge (which is just a rivet) seizes.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- Blacklab467
Ok thanks for that, I'm going to order them tomorrow and I'll find a kit. Be nice to get that working again. Next week is the Haldex pump and filter and if the DEM is good, I'll be out of things to fix on this car!
2003 XC 70 (sold)
- - Pete -
There’s always something to fix
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- 729 Views
Last post by RickHaleParker
- 10 Replies
- 1409 Views
Last post by JRev
