You need to replace every oring you touch in the system. The condensor can be inspected for physical damage and reused. Drier always gets replaced.
The evaporator usually look like this and need replacement
98 xc ac leak; any part replacement recommendations while cleaning engine bay?
- Has thanked: 1505 times
- Been thanked: 3818 times
Re: 98 xc ac leak; any part replacement recommendations while cleaning engine bay?
- CIK7
- Has thanked: 327 times
- Been thanked: 87 times
friend ordered new evap yesterday eve. ill add drier to my cart.
- CIK7
never knew anything about drier, glad you said something. going to look for onescot850 wrote: ↑24 Jul 2020, 17:23 Of the other replacement parts, drier is #1 to buy. Pointless repairing system and not fitting new drier. There is a recommended time once a system has been repaired that you should fit a new drier otherwise it absorbs a lot of moisture. Aftermarket ones are ok for the most part. Only issues I have had with both the evaporator and drier aftermarket was they would not allow the snap rings to fit as they were either slightly too large or out of round on the ends. Both fixed by careful filing.
Has to be new. The drier has silica gel inside which absorbs mositure
The Volvo mantra for maximum time open for drier replacement is 24 hours
The aftermarket Rein replacement is under $15 from FCP
Rein bRand is good for our cars.
Under $20
Big metal can with two oackets of “do not eat “ Stuff
Under $20
- ZionXIX
- Has thanked: 65 times
- Been thanked: 194 times
Be warned, I had to slightly bend the neck on my rein dryer for a better fitment.
wheelsup
- Year and Model:
- Has thanked: 15 times
- Been thanked: 20 times
Have fun 'bro
I used a harbor freight air powered pump (read: not efficient) and to this day it still works, although my clutch is going slowly even with the added pressure with zip ties.
1995 850 GLT Wagon w/ 200,000 miles
- CIK7
I'm assuming you are just doing maintenance with dash out. This here is my junk car soon to be trailer car. I cut out the giant wire snake that trails underneath the inside of windshield. Also 2 of the mega wiring harnesses. Lol
Keep picking at. That, there is a lot of good stuff still on that car...
Once the vultures leave, you are close
- smacknab
- Has thanked: 97 times
- Been thanked: 43 times
My foot vent gets bigger with every passing day
07 V50 T5 AWD M66 ~146k miles
- 1378 Views
Last post by instarx
- 596 Views
Last post by EagleEyecincuenta5
