2.5T VVT Hub center bolt question...
Been thanked: 504 times
Post by cn90 »
The bolt that mates the VVT to the cam shaft is torqued to about 85-90 ft*lb...
Do you rely on the torque only?
Does anyone here add a drop of Loctite to make sure it does not come loose?
Been thanked: 4065 times
Volvo say no, so I don’t. It’s too oily for loctite to setup right anyway, I think.
90 ft lbs is really tight. It’s not going anywhere
- Pete -
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
I don’t, and I clean my bolts with brake parts cleaner.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
The bolt is clean, no thread glue on it. Make sure the three outer hub to sprocket bolts are tight, mine were slightly loose. Ive read of someone that had these bolts fall of, made lots of noise as the hub turned.
https://forums.swedespeed.com/showthrea ... -to-repair
2001 XC70 factory M58
2002 XC70 auto (parts car)
jonesg
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
cn90 wrote: 15 Aug 2020, 15:25 The bolt that mates the VVT to the cam shaft is torqued to about 85-90 ft*lb...
It would be like putting loctite on lugnuts.
Post by cn90 »
Does anyone here ever break this bolt?
Can I re-use this bolt?
Katten
Year and Model: S80 3.2 2007
Post by Katten »
If I remember correctly VIDA instructed to add engine oil to the threads when I replaced thw VVT on our V70 2.4 170hp NA engine.
Can double check if you want me to.
Post by cn90 »
The link below says we need 3/4" drive T55 bit...
http://volvospeed.com/vs_forum/topic/15 ... ng-timing/
My T55 bit is 3/8" type.
Thoughts?
A 3/8 t55 will work fine. I’ve never heard of this breaking, but make sure your T55 bit is sharp and new. If the bolt looks gnawed on, pm me for a spare.
jonesg
Post by jonesg »
3/8 or 1/2 inch torque wrench is plenty enough .
Go with whatever size torque wrench you own.
