850 -remfg starter not quite fitting in bracket
Turbolena
- Year and Model: 850 Turbo Wagon 1994
- Has thanked: 2 times
Has anyone else experienced a re-manufactured Bosch stater for the 850 not quite making to the left side bracket attachment when the pin and right hand bolts are attached? Should I shim with washers? Or not even bother with the bracket attachment?
1994 850 Turbo Wagon
2006 V70R
2006 V70R
- Been thanked: 4069 times
Discussed in Tinas awesome starter replacement thread from 2009!
viewtopic.php?f=1&t=24199
There is a right side bracket that Volvo discontinued, which you can remove. If you really want to torture yourself installing it, it goes onto the removed starter first, the starter is mounted , the m8 bolt started, the two m10 x40 bolts started, then everything get tightened.
- Has thanked: 2205 times
There are 2 different brackets as there are 2 starter case lengths.
Turbolena
Did the part get removed for the p80 frame thought, it seemed like it was for the p2 models. I have the job done except that if I torque that I can't get the starter snug with the bracket on the passenger side attached.
abscate wrote: 16 Aug 2020, 04:04 Discussed in Tinas awesome starter replacement thread from 2009!
2006 V70R
2006 V70R
All P80's I have worked on have one of the 2 end case brackets. They both mount to the same holes.
I’m now running four P80s without the bracket.
5 year update, still running lots of p80 sans bracket.
If you remove it, make sure you counterhold the bolts so you don’t unscrew your starter case.
- 2617 Views
Last post by db130
- 249 Views
- 10 Replies
- 6419 Views
Last post by volvolugnut
- 500 Views
Last post by methdon3
- 541 Views
Last post by matthew1
