2016 V60 Oil light
Tracie1216
- Year and Model: 2016 V60
So I looked for another topic similar but didn’t see an issue exactly like mine. So I keep getting the no oil pressure stop engine notification. So I check the notification on the screen and see what my levels are. They are not below the sensor level. But it will keep going it and progressively get worse with notifications and the check engine light will eventually come on. So I add a little like maybe less than half a quart. It will stop the sensor and will be fine for a little bit then again sensor light will come on start all the nonsense again. Usually starts when I’m taking a turn. I have no leak nothing under vehicle no oil drops, nothing. So it starts again then I’ll put more oil in and it stops. But I do not have an oil leak. What’s the deal?
mipadesi
- Year and Model: 02 V70 2.4 n/a
What weight oil are you running? Maybe backprobe the pressure sensor wires for continuity with a multimeter when the condition appears. I'm not familiar with your car, but usually it's two wires and should read infinity/open lead on ohm setting while running. You could try putting a new sensor in since they're relatively cheap usually...Maybe an expert will be around soon.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Oil Consumption issue? See if it applies to yours. The oil can only leak, go into the radiator or out through the piston rings.
https://forums.swedespeed.com/showthrea ... on-Lawsuit
Technical Journal - NHTSA
Apr 16, 2019 - Lubrication and oil system/Excessive oil consumption. VST Operation ... 2016. V60 (-18). B5254T12. 2015, 2016 V60 Cross Country. (-18).
https://static.nhtsa.gov/odi/tsbs/2019/ ... 4-9999.pdf
- 7042 Views
Last post by cyrker
- 1163 Views
Last post by URDRWHO
- 5726 Views
Last post by carlosabh71
- 844 Views
Last post by zotan
- 755 Views
