Non adjustable timing on P80s. The ECU controls timing on these cars.
I’m leaning to a bad coil module giving me weak spark unable to ignite.
Part number 1275174
Anyone give me feedback on
Volvo
Bosch
Meyle
mTC
1998 V70 NA M56 Crank (compression, spark, fuel ok) No-start - [incorrect install of distributor drive plate ] Topic is solved
- callahanoffroad
- Year and Model: 1995 850
- Has thanked: 16 times
- Been thanked: 53 times
abscate wrote: 17 Aug 2020, 18:25 Non adjustable timing on P80s. The ECU controls timing on these cars.
Part number 1275174
Volvo
Bosch
Meyle
mTC
Bosch Bosch Bosch Bosch Bosch Bosch.
Not meyle. I am normally the #1 advocate for a cheaper part but my meyle coil failed after 15k miles (6 months).
Do you have a parts car you can pull a coil off of?
Also front fire is where the ether or other flammable liquid explodes through the front of the engine or intake as opposed to the back hence front fire instead of back fire. This fire can easily melt a mass airflow sensor. Which happened to me on my first Volvo.
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
+1 on the coil.
Had a similar issue with my last v70. Resulted in a no start, and when we did have it started it sputtered, misfired, and stalled out quite rapidly.
Hopefully that is the issue.
2008 S60 2.5T Auto (Sold)
Here’s a video of my sparks. This is notoriously hard to film because the spark duration and frequency during cranking is near frame rate but. You can see some sparks in the video
Current thinking, this is a weak spark and new coil is needed
IMG_1196.MOV- 1998 spark check
- (17.76 MiB) Downloaded 156 times
- SonicAdventure
- Year and Model: 1996 850 wagon
- Has thanked: 59 times
- Been thanked: 12 times
I found the 98's coil, its a dusty and old original Bosch, but car was running at the time of disassembly.
Like the car, the coil is "as-is, no warranties expressed or implied" ha -
Waiting on parts
Confirmed that I put the cams inthe right place
Replaced with known good coil, no start
Cranking weak. Check spark, no spark at cylinder
BatteRy voltage 11.9, on charger
Check voltage at charger , 11.9
Switch to backup charger , now pulling 4 amps
Your killing me , Earl
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
You mentioned slight gasoline smell at exhaust before. Could this thing be hopelessly flooded?
Earl is not known to be stubborn like this.
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- 17 Replies
- 2706 Views
Last post by Dingo957
- 26 Replies
- 4396 Views
Last post by momentumbob
- 1128 Views
Last post by nmotzing
- 28 Replies
- 5750 Views
- 514 Views
Last post by oragex
