1998 V70 NA M56 Crank (compression, spark, fuel ok) No-start - [incorrect install of distributor drive plate ] Topic is solved
Been thanked: 4071 times
Non adjustable timing on P80s. The ECU controls timing on these cars.
I’m leaning to a bad coil module giving me weak spark unable to ignite.
Part number 1275174
Anyone give me feedback on
Volvo
Bosch
Meyle
mTC
callahanoffroad
Year and Model: 1995 850
Has thanked: 16 times
Been thanked: 53 times
Post by callahanoffroad »
abscate wrote: 17 Aug 2020, 18:25 Non adjustable timing on P80s. The ECU controls timing on these cars.
Part number 1275174
Volvo
Bosch
Meyle
mTC
Bosch Bosch Bosch Bosch Bosch Bosch.
Not meyle. I am normally the #1 advocate for a cheaper part but my meyle coil failed after 15k miles (6 months).
Do you have a parts car you can pull a coil off of?
Also front fire is where the ether or other flammable liquid explodes through the front of the engine or intake as opposed to the back hence front fire instead of back fire. This fire can easily melt a mass airflow sensor. Which happened to me on my first Volvo. :-) so double check your maf abscate
yanga001
Has thanked: 62 times
Been thanked: 115 times
Post by yanga001 »
+1 on the coil.
Had a similar issue with my last v70. Resulted in a no start, and when we did have it started it sputtered, misfired, and stalled out quite rapidly.
Hopefully that is the issue.
2008 S60 2.5T Auto (Sold)
Here’s a video of my sparks. This is notoriously hard to film because the spark duration and frequency during cranking is near frame rate but. You can see some sparks in the video
Current thinking, this is a weak spark and new coil is needed
IMG_1196.MOV
1998 spark check
(17.76 MiB) Downloaded 157 times
bronco
Year and Model: 1998 V70
Has thanked: 49 times
Been thanked: 24 times
Post by bronco »
do si do the coil onto one of your other 3 dozen 1998 V70 's to rule it out :D
SonicAdventure
Year and Model: 1996 850 wagon
Has thanked: 59 times
Been thanked: 12 times
Post by SonicAdventure »
I found the 98's coil, its a dusty and old original Bosch, but car was running at the time of disassembly.
Like the car, the coil is "as-is, no warranties expressed or implied" ha -
Waiting on parts
Confirmed that I put the cams inthe right place
Replaced with known good coil, no start
Cranking weak. Check spark, no spark at cylinder
BatteRy voltage 11.9, on charger
Check voltage at charger , 11.9
Switch to backup charger , now pulling 4 amps
Your killing me , Earl
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
You mentioned slight gasoline smell at exhaust before. Could this thing be hopelessly flooded?
Earl is not known to be stubborn like this.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
Azik09
Year and Model: S70 T5, 1997
Has thanked: 2 times
Been thanked: 31 times
Post by Azik09 »
abscate wrote: 18 Aug 2020, 05:55 Here’s a video of my sparks.
Just watch this video at low speed. Firing order is wrong, 1-4-3-2-5. Must be 1-2-4-5-3.
If my English is bad, please correct me :oops:
