96 N/A auto and 96 N/A 5sp ECUs interchangeable?
Has thanked: 1611 times
Been thanked: 4072 times
Detail around the clutch pedals and release bearing will tell you if it’s factory or swap. Also routing of shift cables
There are not many swaps out there.
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
Okay, I found the VIN decoder at www.volvotechinfo.com to actually list trans types on some cars. I plugged in the VIN you list, and it says Auto. plugged in an easy one, US850R from Row 52, auto, threw in an S60R, it just said AWD, some random V70s, all auto. May be database driven since this s Volvo USAs Tech info site. It show character 9 (code ID 6) to be trans type rather than "Check Digit" like most VIN Decoders. If this works, it could eliminate some fruitless junkyard searches, even if they are fun adventures!
Current Volvos:
I know US requires a check digit while EU does not, so that decoder is still ???
