2003 volvo s40 1.6 won't start
Longdog
Year and Model: 2003 s40
Post by Longdog »
Hello all can anyone help my s40 1.6 won't turn over the battery went dead and have charged it up and it still won't start am I right in thinking it could be the starter motor. Is there anything I could try before getting a new one
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
The first generation X40s are notorious for the column lock going defective. When this happens the key will not turn all the way to position III (Start).
1. Remove the cover from the bottom of the dash under steering column.
2. Locate the electrical part of the ignition switch and remove the one screw holding it in.
3. Turn key to position II (ON).
4. Grab the electrical part of the ignition switch and rotate it clockwise.Top moves toward you.
Did it crank over and start ?
Active
Past
Longdog
Post by Longdog »
I will give that a try when I finish work and let you know
Longdog
Post by Longdog »
Is that copper looking beaded wire fixable
Longdog
Post by Longdog »
Sorry pic didn't upload first time lol
alschnertz
Year and Model: 1995 854T
Has thanked: 2 times
Been thanked: 12 times
Post by alschnertz »
Generally, anything is fixable.
Is that your starter or just a photo from the internet?
Looks like that wire may have heated up so much it disintegrated.
My guess would be either a short in the starter, someone cranked it for many minutes on end or too much (well above 14V) were applied. If that's how you found your wire, I would try to find out why it fried. I would not just replace that without more diagnosis.
Though the ignition switch is prone to failure, If everything else has always been well with the car, I'd lean towards the starter having some kind of internal short.
'84 Prelude
'06 MPV
'13 Ford Focus SE
