Actually what you want to know is who has tried it and with success or failure. More so than what might work, what the parts books say, etc.
That is the greatest strength of the forum, getting the practical (empirical) information.
I haven't tried it and don't know who has! But we have the search function ...
viewtopic.php?f=1&t=72607&p=382745&hili ... ck#p382745
viewtopic.php?f=1&t=65556&p=339745&hili ... ck#p339745
The first post is especially informative, from BigWill. I think the short answer is "yes."
are P80 racks fully interchangeable?
- Has thanked: 312 times
- Been thanked: 818 times
- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 77 times
- Been thanked: 59 times
No, actually. There was a change in engine mount location at some point. I can't recall exact years or chassis numbers. I believe it was during the latter S/V/C years.
Azik09
- Year and Model: S70 T5, 1997
- Has thanked: 2 times
- Been thanked: 31 times
Yes.850oldschool wrote: 18 Aug 2020, 21:18 if a used rack come with tie rod ends will it fit any P80? Or, more particularly, can I put an S/V70 rack on my 850?
If my English is bad, please correct me
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
Thanks, everybody! My odds look pretty good. I’ll wait on the subframe and steering column until the rack arrives. If P80’s have a kitchen sink I’m sure Rick knows the part numbers of all five versions.
I’m thinking I’ll do subframe bushings when I drop it, plus maybe rear motor mount, it’s got about 10 years on it. And PS lines, of course. They’re rusty and the rubber is pretty hard. The Gates lines are the only thing in the middle ground between Sunsong and OEM Volvo. Are they any good, or just Sunsong in a different package?
- Has thanked: 1611 times
- Been thanked: 4075 times
TRW and SMI racks are both listed in the Volvo web- store, with different part numbers
Someone pasted recently that you can tell them apart by looking at the cap on the end of the shaft gear
Here's the best consolidation I know of for using the hex cap versus round cap to make the distinction: viewtopic.php?f=1&t=75524 see especially pics on pages 2 and 3
And here's some good info from IPD about original equipment: https://www.ipdusa.com/products/5801/11 ... 413,T10029
And a quote of the most useful bits from the above mentioned IPD page, which supports the overwhelming (!) evidence that the racks are interchangeable:
"These models were originally equipped with SMI racks:
1999 S70 AWD with Chassis Number 572015 and higher
1999-2000 V70 AWD/XC with Chassis Number 549831 and higher
1998-2000 S70 FWD with Steering Rack Code "5" (Position 8 of Product ID)
1998-2000 V70 FWD with Steering Rack Code "5" (Position 8 of Product ID)
1998-2004 C70 with Steering Rack Code "5" (Position 8 of Product ID)
If you have an early 1998 S70 FWD or 1998 V70 FWD with 7 digit Product ID then your car originally came equipped with a TRW rack not SMI.
See attached technical article for more information regarding Product ID plate.
If the rack was ever replaced on your car, then it could be either style.
It's not a bad idea to buy both styles and simply return the units you don't use."
