Constant knock sensor code - 850R
Knock sensor code tripped when I was going 30mph barely any throttle. When I clear the code it comes on immediately after restarting the car, within a second or two at most. Is it possible to reach the sensors without removing the manifold?
- Has thanked: 312 times
- Been thanked: 818 times
It's really tough to reach them but you can.
This code is almost never an actual knock sensor problem - usually the wiring is damaged or connections are dirty.
- Has thanked: 1611 times
- Been thanked: 4075 times
What year is this? What code is being read? Many readers don’t map the p code to text correctly
1996, code P0326 - Knock Sensor 1 Circuit Range/Performance (Bank 1) is the exact textabscate wrote: 23 Aug 2020, 04:07 What year is this? What code is being read? Many readers don’t map the p code to text correctly
You will find very few clear this code with replacing the knock sensors, it’s usually poor running, wiring, or corrosion
Don’t overtughten the sensor or you will break them. Look up the spec torque, it’s low. Can’t be too loose either
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
It’s possible to wriggle your hand in there. and also to view with a mirror. My wire was severed, perhaps by a rodent.
I reached my hand behind the intake manifold and wiggled the connector a bit and now no more code, I’m almost certain it’s the wiring and I’ll have to get in there to fix it. Thanksabscate wrote: 23 Aug 2020, 08:39 You will find very few clear this code with replacing the knock sensors, it’s usually poor running, wiring, or corrosion
- 2055 Views
Last post by cn90
- 28 Replies
- 5600 Views
Last post by SuperHerman
- 1259 Views
- 545 Views
Last post by Evolvo850B
- 1774 Views
Last post by 5ft24
