1998 V70 NA M56 Crank (compression, spark, fuel ok) No-start - [incorrect install of distributor drive plate ] Topic is solved
Been thanked: 4065 times
Azik09 wrote: 21 Aug 2020, 10:38
abscate wrote: 18 Aug 2020, 05:55 Here’s a video of my sparks.
Just watch this video at low speed. Firing order is wrong, 1-4-3-2-5. Must be 1-2-4-5-3.
I will double check the spark plug wires. Again
The video could be aliasing since the shutter speed and frame rate is comparable to DUT , for you electrical engineers out there
I’m giving the cars the weekend to talk to each other , GeStarter Therapy
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
abscate wrote: 17 Aug 2020, 11:41 You guys with pre 1999 manuals, does the clutch switch inhibit cranking only like a 1999 or does inhibit ignition too!
My S70 cranks with or without the clutch depressed...
Retired:
2015 Volvo S60, T5, 85K
I wonder if Gestart Therapy will help Depressed Clutches
I just can’t stop myself, sometimes.
SonicAdventure
Year and Model: 1996 850 wagon
Has thanked: 59 times
Been thanked: 12 times
Post by SonicAdventure »
abscate wrote: 24 Aug 2020, 04:41 I wonder if Gestart Therapy will help Depressed Clutches
you're talking about clutches; if you want to stop - its one pedal to the right... :lol:
bcfischer
Year and Model: 1999 V70xc
Has thanked: 14 times
Post by bcfischer »
Abscate:
I had a crank no-start condition on my 99 V70 XC concurrent with a fuel pump issue last year.
Pretty pedestrian compared to some of the other suggestions, but are you able to swap out a known good antenna ring (fits around the ignition key) for the one in the car with the crank no-start condition? I believe that the engine will crank, but ignition will not fire with a bad antenna ring.
Just a thought....
Brian
Brian Fischer
Duluth, Minnesota, USA
late year 1999 V70XC (Chassis 587997)
theWIFES_S70
Well, they have a lot to be depressed about... less and less MT cars here in the US! And the "MT" that are being made are these clutchless pieces of crap! :lol:
Retired:
abscate wrote: 21 Aug 2020, 11:37
Confirmed wires are in positions, counterclockwise order
12453
With number 1 on the tall post
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Time to go old school. Pull No. 1 plug and turn crank to get top dead center. Pressure (or vacuum) the cylinder to confirm all valves are closed (ignition cycle position). Confirm the distributor is pointing to the No. 1 plug.
volvolugnut wrote: 25 Aug 2020, 12:45 Time to go old school. Pull No. 1 plug and turn crank to get top dead center. Pressure (or vacuum) the cylinder to confirm all valves are closed (ignition cycle position). Confirm the distributor is pointing to the No. 1 plug.
This is going to be on the morning agenda
