1998 V70 NA M56 Crank (compression, spark, fuel ok) No-start - [incorrect install of distributor drive plate ] Topic is solved
- Has thanked: 311 times
- Been thanked: 817 times
I think you just checked the cams so this is probably irrelevant but: Is the little metal mounting disc under the CPS (and the distributor one for that matter) in the correct orientation? It's possible to mount them wrong and still reassemble, then they are 180 out of phase.
I have not. I thought these were offset, since they go into the cam slots, to prevent this. This might be very good news,erikv11 wrote: 25 Aug 2020, 19:08 I think you just checked the cams so this is probably irrelevant but: Is the little metal mounting disc under the CPS (and the distributor one for that matter) in the correct orientation? It's possible to mount them wrong and still reassemble, then they are 180 out of phase.
So , with the crank in the mark and the cam gears 180 off the mark
Distributor points to cylinder 1
With the crank on the mark and the cams both on the mark, the distributor points to cylinder 4
Which is right??
Which is right??
Following Erik’s lead , I got to thinking this exactly fits every symptom. No firing , frontfire on ether , good spark at plugs
So, I set timing to marks, pulled cap, cylinder 4 firing.
Double check distributor drive plate (couples cam slot to the distributor rotor, one M6 bolt. It looked good , seated it by feel.
Cylinder 4 firing
I go to the intake cam sprocket. Do I have that in backwards or rotated by 120? Doesn’t look possible.
Back to the distributor drive plate. I take it out, look at the cam slots and install it carefully
Guess what? Now the distributor points to cylinder 1
Are you kidding me ??
He tries the key......and Earl comes to life, first time since January
Cylinder 4 firing
IMG_1292.MOV- (22.83 MiB) Downloaded 154 times
The Volvo horns are awarded in gold to both Professor Potato Erik and the Villagepc for post and on guidance to this as the trouble spot
- Has thanked: 987 times
- Been thanked: 1075 times
The team wins again and the crowd goes wild! Well done.
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
Hooray. Earl is alive and well again. Someone in VT must be very happy right now
Kudos to abscate for his willingness to spend a lot of time, energy and brain power to help out a fellow Volvo owner!
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
markone
- Year and Model: 2007 V70
- Has thanked: 21 times
- Been thanked: 14 times
Wow. Earl's epic odyssey to Albany. And superhuman effort by abscate. As 850 LPT, points out, what a lot of effort.
2006 V70 NA/manual trans, 165k
2007 V70, NA/manual trans, 143k miles
2023 BMW X1, 29k miles
2018 Jeep Grand Cherokee LTD, 91k miles
2007 Malibu Response LXi, Ebony/white, 340 hp, 395 hours
1997 850 Sedan NA, manual trans, sold at 330k miles
1998 V70, NA/manual trans, sold at 365k miles
15 days to figure this out. Probably about 4-5 hours of actual work time.
Inexperience with the mechanical distributor major factor.
I was putting in the plate by feel, and it will mount up 180 out and look and feel right.
Once I stuffed my mug into the air filter space and really visually matched the cogs to cam slot, all good.
MVS KNOWLEDGE
The rotor position does belong at cylinder 1 with the crank and cams on the marks, and cylinder 1 is near TDC
MVS KNOWLEDGE
- 17 Replies
- 2699 Views
Last post by Dingo957
- 26 Replies
- 4380 Views
Last post by momentumbob
- 1124 Views
Last post by nmotzing
- 28 Replies
- 5733 Views
- 513 Views
Last post by oragex
