1998 V70 NA M56 Crank (compression, spark, fuel ok) No-start - [incorrect install of distributor drive plate ] Topic is solved
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1076 times
Post by volvolugnut »
This proves again - what you don't know is not as bad as what you THINK you know, but is just WRONG.
Extra points for going back to it until fixed.
Has thanked: 2207 times
Been thanked: 1852 times
Like Rocket99 with his challenge with coil packs, what volvolugnut says I am a +1 to what he says. Sometimes walking away from an issue helps to re-think and issue and then going back to basics helps. Congrats on getting it figured out! Neil.
Been thanked: 4071 times
FLXC90 wrote: 17 Aug 2020, 17:12 Ether - I did not get running on ether, I did get an intake manifold backfire which blew off snorkel. was it just swamped with ether, or does this indicate firing with the intake valve open?
You were totally on point with this
smacknab
Has thanked: 97 times
Been thanked: 43 times
Post by smacknab »
2020 is finally turning around! Nice work
07 V50 T5 AWD M66 ~146k miles
volvolugnut wrote: 17 Aug 2020, 17:36 You have spark at the plugs, BUT do you have spark at the proper time in the cycle? This has a distributor, right? Did you remove the distributor doing work? Try using an old timing light to check proper spark timing. Distributors can be tricky to get proper spark timing.
Triple award of the Volvo horns to Mr Lugnut
THANKS! to absacate.
(thanks button not shown)
This has become a thankless Forum
Replaced the heater bulkhead so that miss Vermont 2020 has heat
Deep flush of cooling system
Bit toning up ancillaries.
Took pEarl out for a hot 60 mph run. Throttle body lever fell off on lift. Fixed with a spare throttle body lever retainer, which can be used to hold her in a pony tail
villagepc
Year and Model: 98 V70m | Stage III
Has thanked: 3 times
Post by villagepc »
Glad ya got it running!
____________________________________________
1998 V70 T5M R Clone | IPD / ARD Stage 3
2008 S80 3.2 - not too shabby
1991 740 Turbo - 2.5" lift, 100% madness
We got the Duchess of a Earl back home safe and sound. We had a wonky idle which cleared when we unplugged the Idle air control valve so that probably needs cleaning. Thread bumped.
Here she is, back with her family!
