Ace Hardware does not carry bolt with square head.
Try NAPA or OReilly auto parts.
FDPP #2
- mkc1
- Year and Model: 850 GLT 1997
- Has thanked: 27 times
- Been thanked: 10 times
It sounds like from gnalan's other thread that a replacement ETM is needed. Would the FDPP be able to find/provide/send one to him?
"Learning mechanics is easier than learning male psychology. You can figure out an engine; you can never figure out a man." -- Pepa Marcos, Mujeres al borde de un ataque de nervios [paraphrased]
1997 850 GLT "Volvo"
1997 850 AWD "Junior" (for parts, sadly)
- Has thanked: 987 times
- Been thanked: 1078 times
I also think his ETM is failing.
- Has thanked: 2864 times
- Been thanked: 1332 times
Yes.mkc1 wrote: 27 Aug 2020, 17:12 It sounds like from gnalan's other thread that a replacement ETM is needed. Would the FDPP be able to find/provide/send one to him?
The symptoms overlap with failing ETM symptoms, certainly.
- gnalan
- Year and Model: 2001 S60
- Has thanked: 557 times
- Been thanked: 135 times
I've checked everything else that I could think of so far, along with others suggestions to check.
I wish it wasn't so expensive to replace the ETM. I looked at different tutorials on fixing it myself by replacing the TPS, but it doesn't look like something I can do myself without causing more problems.
I really appreciate the help from everyone here, both with parts and advice. If someone could help with the cost of the XeMODeX ETM, I could make payments to pay it back. I just can't afford the whole amount at once. It'll probably take me 4 to 6 months to pay back, but if someone is ok with taking payments I can pay it back.
Consensus? Are there any dissenters to declaring a failing ETM diagnosis?
gnalan, Did you run through the XeModeX ETM test flowchart? Did results point to ETM failure?
- gnalan
I did go through the flow chart, and when I got to the step where I removed and reinstalled fuse #7 the ETM clicked on, whined for about 10 seconds, and then shut off. I did that about a six times to make sure, thinking maybe the clicking sound only showed up when it wanted to. The flow chart says it should whine for 6 seconds. I don't know if the difference in time matters or not. The flow chart then had me check for MAF codes, which I don't have any codes related to the engine at all. I attached a graph of the different parameters that keep jumping around. Can anyone tell by looking at the pic if it's the MAF, ETM, or possibly both? Maybe something else altogether? I didn't find any vacuum leaks anywhere, and looking at the graph I don't really know what's causing my problems.volvolugnut wrote: 27 Aug 2020, 18:49 gnalan, Did you run through the XeModeX ETM test flowchart? Did results point to ETM failure?
- gnalan
The graph is with the car at normal operating temp. When it was cold it did the same thing, but I didn't get a screenshot.
- 2714 Views
Last post by YYC850
- 29 Replies
- 4126 Views
Last post by foggydogg
- 1331 Views
Last post by volvolugnut
- 642 Views
Last post by rcherry506
