Fuse #14 30A ABS and Traction control.
850 T5 Blue Smoke after a couple hours of sitting
- RickHaleParker
- Been thanked: 979 times
Active
Past
Past
fantajuice
- Year and Model: 1995 850 2.0 T5
- Been thanked: 2 times
That fixed the AbS and tracs.
However after changing changing the coolant yesterday (old was brown and muddy), I have stumbled upon an issue I really don't like - pressure in the coolant system.
I really really hope it isn't the head gasket.
The symptoms are as follows: coolant level in minimum, cap off, start the engine, engine gets warm and slowly the coolant level starts to rise. In about 20 minutes it rises to maximum. After that it starts to over flow until you shut off the engine, after which it burbles a bit and all the coolant lowers back down, to minimum.
With the cap closed the level stays the same as before starting the engine, but eventually starts leaking from the main hose underneath the expansion tank, due to the pressure I presume. If I take off the cap before it starts doing that, it immediately starts over flowing.
Temperature does not rise over normal according to the temperature gauge. The coolant doesn't dissapear.
Car blows warm air, lower and upper radiator hoses get hot.
Please tell me I have an air bubble somewhere where I couldn't figure it out and that I don't have to do the head gasket.
- RickHaleParker
Normal: Coolant systems are pressurized in order to raise the boiling point of the water. Lower the pressure and the boiling point lowers. Look up Ideal Gas law.fantajuice wrote: 22 Sep 2020, 22:57 The symptoms are as follows: coolant level in minimum, cap off, start the engine, engine gets warm and slowly the coolant level starts to rise. In about 20 minutes it rises to maximum. After that it starts to over flow until you shut off the engine, after which it burbles a bit and all the coolant lowers back down, to minimum.
If a hose is leaking the hose is defective. The hose is most likely the original that would make it 25 years old.
Active
Past
Past
fantajuice
It's more so that it starts pushing out the liquid from underneath the hose, even with the clamp tightened.RickHaleParker wrote: 22 Sep 2020, 23:24Normal: Coolant systems are pressurized in order to raise the boiling point of the water. Lower the pressure and the boiling point lowers. Look up Ideal Gas law.fantajuice wrote: 22 Sep 2020, 22:57 The symptoms are as follows: coolant level in minimum, cap off, start the engine, engine gets warm and slowly the coolant level starts to rise. In about 20 minutes it rises to maximum. After that it starts to over flow until you shut off the engine, after which it burbles a bit and all the coolant lowers back down, to minimum.
None of this happened before.
- RickHaleParker
Everything has a start time.fantajuice wrote: 22 Sep 2020, 23:44 It's more so that it starts pushing out the liquid from underneath the hose, even with the clamp tightened.
The hose may of expanded. It is now bigger around that could explain why it does not hold pressure like it did before.
If you think it a head gasket. Go to a auto parts store and get a Combustion Leak Tester. It is a chemicial test that will sniff out combustion gases in the coolant.
Active
Past
Past
fantajuice
I'll do the test today, however, again, when driving yesterday, downshifting from 3rd to 2nd, it didn't quite want to go in and suddenly I heard a crack.
Now bottom row of gears is basically gone, I can get it into fourth with some ease, but second is wayyy wayyy far down and reverse is near impossible to find.
First, third and fifth are fine.
Gear shifter linkage? What should I check out?
- RickHaleParker
Odds are OK. Evens are not. The linkage is two cables. My first guess is you cracked the plastic shifter base rendering one of the cables inoperable. Have somebody work the shifter as you observe the linkage cables at the transmission.fantajuice wrote: 24 Sep 2020, 09:25 First, third and fifth are fine.
Active
Past
Past
fantajuice
Good news on the head gasket test, it isn't buggered.
Bad news on everything else not related to the car - I'll have to drive around with a screwed shifter for a couple weeks because I got thrown out of the garage I was renting because apparently I was there so much, that someone called the cops on me for having an "illegal workshop".
I also want to find the turbo leak I've got going, but I've no idea where to start. The car has a tune (but I have no clue what's been done, ECU has tuning written on it, previous owner had no clue either), and when I bought it, according to the boost gauge, went up to 1.5 bar.
Now it does 1 bar and in third gear foot flat to the floor, the boost starts to fluctuate between 1-1.2. Still faster than a 4.2 A8 from a rolling start with half the fuel economy
- RickHaleParker
Should of told the cops "I am not much of a business person .. I only have one customer and it is me" .fantajuice wrote: 26 Sep 2020, 02:41 I also want to find the turbo leak I've got going, but I've no idea where to start.
Smoke the leak out. Google "DIY Smoke machine" There are all kinds of way to make a smoke machine.
Active
Past
Past
- Been thanked: 4069 times
If they don’t crack down On rogue garages you get this guy in your neighborhood, everyone complains until their car breaks, then suddenly you are loved.
- 921 Views
- 19 Replies
- 7441 Views
Last post by EngineeringBloke
- 10 Replies
- 3092 Views
Last post by misha
- 10 Replies
- 1835 Views
Last post by RickHaleParker
- 2011 Views
Last post by mateqh
