FDPP #2
Has thanked: 1611 times
Been thanked: 4075 times
I don’t think 6-10 seconds difference is meaningful
While the data looks nasty the scale is tiny on the left. The only thing jumping is theMAF READING AT IDLE, thats all over the place. Check all the induction hoses for clamps by removing, inspecting , and reclamping, just labor
mkc1
Year and Model: 850 GLT 1997
Has thanked: 27 times
Been thanked: 10 times
Post by mkc1 »
abscate wrote: 28 Aug 2020, 04:49While the data looks nasty the scale is tiny on the left.
If I'm reading the graph correctly, the desired value for the throttle angle varies from 3 - 6% but the actual value varies from 1 - 20%. That doesn't seem right, does it? I'm no expert, especially as my 850 doesn't have an ETM.
"Learning mechanics is easier than learning male psychology. You can figure out an engine; you can never figure out a man." -- Pepa Marcos, Mujeres al borde de un ataque de nervios [paraphrased]
1997 850 GLT "Volvo"
1997 850 AWD "Junior" (for parts, sadly)
gnalan
Year and Model: 2001 S60
Has thanked: 557 times
Been thanked: 135 times
Post by gnalan »
These were both done at operating temp, with the MAF unplugged. Everything still jumps around on the graphs, and the car still acts like it did when it was plugged in.
Why am I still getting a "g/s" reading if the MAF is unplugged? Shouldn't it read 0, or is this normal? Can someone verify on their car and see if there's any MAF signal with it unplugged? I mapped the MAF voltage unplugged also, but it stayed at 0V the whole time so I took it off of the graph so it wasn't too cluttered.
With the MAF unplugged, the ECM calculates air flow based on rpm and uses that value to determine air, and hence fuel, to inject. That’s why the practice of trying to diagnose bad MAFS by unplugging them is poor. My guess is you are observing the calculated air flow from that lookup table
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
That would make sense that it's calculated airflow. I wouldn't look too far into that. I think the ETM is probably on its way out, just looking at these charts and knowing your symptoms.
gnalan
Post by gnalan »
Can anyone help me get an ETM? Should I replace the MAF too? I saw on the XeMODeX that they should usually be replaced together.
I really hope this is the last thing I need to fix. I don't know if the timing belt/water pump has ever been changed. Is there any markings on the belt that I can see with the top cover off to tell whether it's the original one or not?
bmdubya1198
It's not totally necessary to replace the MAF along with the ETM.
gnalan
Post by gnalan »
That's expensive! I'm lucky if I have a tenth of that left at the end of the month, and even that's difficult to do right now.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
bmdubya1198 wrote: 28 Aug 2020, 10:46 It's not totally necessary to replace the MAF along with the ETM.
I agree, there is some evidence MAF fails when ETM fails, but I would not change your MAF yet. I think XeModex used to offer a test for about $150 and will return your ETM if it passes their test. They do this on a machine. You may also pay shipping both ways.
Does anyone have a working, used ETM to try?
bmdubya1198
$150 just to test? Ouch! The test on VIDA costs nothing.
