I don’t think 6-10 seconds difference is meaningful
While the data looks nasty the scale is tiny on the left. The only thing jumping is theMAF READING AT IDLE, thats all over the place. Check all the induction hoses for clamps by removing, inspecting , and reclamping, just labor
FDPP #2
- mkc1
- Year and Model: 850 GLT 1997
- Has thanked: 27 times
- Been thanked: 10 times
If I'm reading the graph correctly, the desired value for the throttle angle varies from 3 - 6% but the actual value varies from 1 - 20%. That doesn't seem right, does it? I'm no expert, especially as my 850 doesn't have an ETM.
"Learning mechanics is easier than learning male psychology. You can figure out an engine; you can never figure out a man." -- Pepa Marcos, Mujeres al borde de un ataque de nervios [paraphrased]
1997 850 GLT "Volvo"
1997 850 AWD "Junior" (for parts, sadly)
- gnalan
- Year and Model: 2001 S60
- Has thanked: 557 times
- Been thanked: 135 times
These were both done at operating temp, with the MAF unplugged. Everything still jumps around on the graphs, and the car still acts like it did when it was plugged in.
Why am I still getting a "g/s" reading if the MAF is unplugged? Shouldn't it read 0, or is this normal? Can someone verify on their car and see if there's any MAF signal with it unplugged? I mapped the MAF voltage unplugged also, but it stayed at 0V the whole time so I took it off of the graph so it wasn't too cluttered.
With the MAF unplugged, the ECM calculates air flow based on rpm and uses that value to determine air, and hence fuel, to inject. That’s why the practice of trying to diagnose bad MAFS by unplugging them is poor. My guess is you are observing the calculated air flow from that lookup table
- Has thanked: 316 times
- Been thanked: 531 times
That would make sense that it's calculated airflow. I wouldn't look too far into that. I think the ETM is probably on its way out, just looking at these charts and knowing your symptoms.
- gnalan
Can anyone help me get an ETM? Should I replace the MAF too? I saw on the XeMODeX that they should usually be replaced together.
I really hope this is the last thing I need to fix. I don't know if the timing belt/water pump has ever been changed. Is there any markings on the belt that I can see with the top cover off to tell whether it's the original one or not?
It's not totally necessary to replace the MAF along with the ETM.
- gnalan
That's expensive! I'm lucky if I have a tenth of that left at the end of the month, and even that's difficult to do right now.
- Has thanked: 987 times
- Been thanked: 1075 times
I agree, there is some evidence MAF fails when ETM fails, but I would not change your MAF yet. I think XeModex used to offer a test for about $150 and will return your ETM if it passes their test. They do this on a machine. You may also pay shipping both ways.bmdubya1198 wrote: 28 Aug 2020, 10:46 It's not totally necessary to replace the MAF along with the ETM.
Does anyone have a working, used ETM to try?
$150 just to test? Ouch! The test on VIDA costs nothing.
- 2691 Views
Last post by YYC850
- 29 Replies
- 4077 Views
Last post by foggydogg
- 1317 Views
Last post by volvolugnut
- 629 Views
Last post by rcherry506
