2001 V70 Crank no Start
01_Nautic_V70
- Year and Model: 2008 XC90 V8
- Been thanked: 8 times
Re: 2001 V70 Crank no Start
And I’d jump it then drive to an auto parts store to get the battery tested. Sounds like a dying battery. Simple fix.
DanelleNavarro
- Year and Model: 2002 v70xc
I'll give that a try. I had the battery, alternater, ignition, and starter tested already and everything came up good... But I will definitely try again.
01_Nautic_V70
If it starts when you jump, and stays running for an extended time you can basically eliminate the starter, alternator, plugs, wires and coil packs as problems. Sure sounds like battery.
DanelleNavarro
Everyone sorry it took me so long to get back to you guys my problem with my crank and no start was definitely the battery so just FYI out there to all make sure that your battery is the right size for your vehicle the old battery was not the right size for my Volvo... Anyways thanks again for everyone's help I really appreciate it and now I'm off to Arizona to get married
- Has thanked: 1505 times
- Been thanked: 3818 times
Batteries are not good presents for brides. BTDT
