Late Manufacture ETM Programming Needed ?
Cillyman
Year and Model: V70. 1999 Base N/T
Post by Cillyman »
I have purchased a used ETM that was manufactured in 2018 and pulled from the exact same car and engine as the failing ETM a V70 1999 5 cylinder non turbo. What are the chances that it will not need to be reprogrammed ? Thanks Scott in MA.
Been thanked: 4070 times
The general stat for a junkyard ETM success rate is 20% but NA is higher, like 80%, last I reviewed.
Cillyman
Post by Cillyman »
What do you mean when you say NA ?
Cillyman
Post by Cillyman »
Duh Naturally Aspirated sorry I knew that just had a brain cramp.
