Replacing the rear calipers is a doozy right? The fact that this car stops on a dime with only front calipers is really something! (That and I love driving the speed limit!)
Really feeling like Job with this car...
I agree can rust in open position. Had it happen on 240. The fault may be internal at the pistons. Could be external at the guide pins.abscate wrote: 31 Aug 2020, 13:37 You can definitely Rust a caliper in the open position. It’s usually rusts in contact and heats up, though
These last about two years Inthe Northeast and then the silver cheese pistons rust up again and seize.smacknab wrote: 31 Aug 2020, 20:42 If you end up needing to replace the rear calipers, it was pretty easy when i did it. I i got some remanufactured ones off rock auto for maybe $40 plus core. I think it's just two 13mm bolts holding them on then bleeding the brakes after, thats assuming the brake line nipple isn't seized too bad.
