Vida 2014D Times out 12/31/2017 23:59 Topic is solved
bronco
Year and Model: 1998 V70
Has thanked: 49 times
Been thanked: 24 times
Post by bronco »
:? I guess the problem is I don't know what a magnet link is
I've heard of bittorrent but never used it before
I guess I'll have to learn some new stuff along the way
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
familiarity breeds contempt .
Kara503
Year and Model: 1996 850 Plat R-Swap
Has thanked: 17 times
Been thanked: 6 times
Post by Kara503 »
Having some trouble with the repack on my Surface running Win10 Home.
When I run script 2, I get a VIDA NOT OK message at the end of the install. The log indicates
Error: install.doinstall.check.installed.version.is.localdb.attached.accessserver.is.attached. Reason: Failed to connect to server (local)\Vida.
Microsoft.SqlServer.Management.Common.ConnectionFailureException: Failed to connect to server (local)\Vida. ---> System.Data.SqlClient.SqlException: A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: SQL Network Interfaces, error: 26 - Error Locating Server/Instance Specified)
I have IE11 installed, and before this I ran script 1 as admin. Any ideas?
96 855 Platinum- Elsa
98 V70R- Goose
06 S40 NA- Hilda
02 VW Jetta TDI wagon- Dizzy
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Kara503 wrote: 09 Jul 2020, 01:22 (provider: SQL Network Interfaces, error: 26 - Error Locating Server/Instance Specified)
Check services.
Active
Past
Kara503
Post by Kara503 »
RickHaleParker wrote: 09 Jul 2020, 01:37
Check services.
Not getting everything you have. Wondering if something in the SQL install pack failed. I can get The server browser to start from this window, but the Active directory helper fails to start no matter what. I've tried re running the SQL part of the re pack quite a few times.
98 V70R- Goose
06 S40 NA- Hilda
RickHaleParker
Something wrong with your SQL server install or your security settings.
Active
Past
Kara503
Post by Kara503 »
RickHaleParker wrote: 09 Jul 2020, 16:47 Something wrong with your SQL server install or your security settings.
Got it figured out, some files were getting missed during the SQL uninstall/ reinstall. Deleted those, installed SQL again, finished everything and now using VIDA on my sisters S40! Thanks.
98 V70R- Goose
06 S40 NA- Hilda
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
What model year included with VIDA 2014D? What version works with 2015 & 2016 XC70?
RickHaleParker
xHeart wrote: 02 Sep 2020, 12:08 What model year included with VIDA 2014D? What version works with 2015 & 2016 XC70?
Vida 2014D was released early 2015. It does contain early 2015 production chassis numbers but not later 2015 production chassis numbers.
There is offline hacked version of 2014D retitled 2015A that is said to contain cars up to 2017. Do not waste your time with 2015A. It is a grossly inaccurate fake. Something cobbled together to get people to buy a DiCE unit form vendor X instead of vendor Y. The offline version of 2015A is a scam.
To read the DTCs on a 2015 not in the Vida 2014D database or a 2016+, use Vdash with a DiCE unit.
Active
Past
xHeart
Post by xHeart »
RickHaleParker wrote: 02 Sep 2020, 12:52
Thank you Rick!
