1979 242 problems, flooding after start
Tig
Year and Model: 1979 242
Post by Tig »
Gifted a 1979 242-139,999 mileS
Second Volvo but not exactly a mechanic😡
Straight body all good. Had safety work done
Alignment, new bushings, some hoses
Then moody when starting- flooded w fuel
then dies HELP
Without computer codes mechanic is helpless ...
Has thanked: 1609 times
Been thanked: 4065 times
Split topic from
2005 XC trailer hitch discussion.
πŸ€”
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
Tig wrote: 08 Sep 2020, 02:12 Gifted a 1979 242-139,999 mileS
then dies HELP
See if the fuel pressure regulator has sprung an internal leak.
Pop the vac line off and check for fuel.
Any hint of wetness ... you should swap it out.
It usually sits on the end of the fuel rail, up front.
Tig
Post by Tig »
Wow thanks so much for a quick response.
You did see -that I not a mechanic.
Is there a picture or illustration or SOMETHING I could look at or even read to understand exactly when where and how to do this?
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Check this video. https://www.youtube.com/watch?v=rqgtTg6IIuY Your engine should be similar.
