Anyone have a DIY for removing rear diff?
diplomaticm3
Year and Model: 2004 xc70
Post by diplomaticm3 »
Got my hands on an almost new rear diff for a 2000 V70r and I’d like to see if I can tackle the job.
Thanks folks.
Been thanked: 4065 times
Big job.
Paging Neil for his thread on this.
Wince
Richard99
Year and Model: 2000 V70XC
Has thanked: 26 times
Been thanked: 23 times
Post by Richard99 »
I think the only way to do it is to completely remove the rear subframe. Here is a video on the process:
Some parts are glossed over but the essentials are all there. You obviously won't be able to cut lines as he does, so some modifications to what he does will be needed.
Eric
1998 Volvo V70 - rear-ended and totaled
2000 Volvo V70XC
2007 Volvo V50 T5 AWD M66
Richard99
Post by Richard99 »
If it hasn't been done you can also replace fuel pump while rear subframe is out
Eric
2000 Volvo V70XC
Richard99
Post by Richard99 »
Here is video for subframe disassembly:
Eric
2000 Volvo V70XC
Has thanked: 2199 times
Been thanked: 1852 times
The rear sub-frame has to be removed as the sub-frame is a 'clam-shell' which is what clamps the rear diff in place. Volvo in their infinite wisdom decided to put the bolts holding the 2 halves together from the top of the sub-frame so it has to come out to to replace the diff.
Other than having a V70R diff I just want to check what you are planning to fit it to. Your profile says you have a 2004 car which is a P2 chassis which is different to the P80 chassis. Not even sure it would be compatible as the P2 rear frame is totally different.
