Thinking about getting rid of my ‘12 Genesis and turning my ‘98 V70 into my daily driver. Will need to make the a/c on my V70 operational to do this.
Suspect it needs an evaporator. IPD shows two on their site. One is Volvo genuine parts for over $400 the other aftermarket for $100-$150.
Thoughts on the genuine Volvo vs. after market please?
Appreciate your input.
Todd
Evaporator: Volvo or After Market
HonestTodd
- Year and Model: 98 V70 -
- Has thanked: 2 times
- Has thanked: 1611 times
- Been thanked: 4074 times
Nissens or Behr are excellent replacements. I’m going on 7 years with my Nissens replacement now
There is a good price inthe Nissens compressor right now, $235 with no core from FCP
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Agreed with previous replies. Not really a job you want to do again by getting the cheapest part you can find.
I'm at 20 years on my original. *nervous*
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- Has thanked: 2210 times
I did have an issue with a Nissens evaporator on an 850. The flange at the bulkhead on the pipes were slightly too large preventing the snap ring being able to get over them to lock them in. A little careful filing (after 5 hours of swearing) and it then snapped in perfectly. Ran great after that though.
One heads up is sometimes the lock springs rust in place. Maybe worth spraying a day before tackling with penetrating oil to help then release.
Good luck!
Good luck!
Another tip. If you know you are replacing the evap just cut the evap off as close to the firewall as you can with a Dremel, in 7 seconds
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
Also cut two small passage ways in the bottom of the new foam so the water can hopefully make it to the drain instead of pooling on one side of the evap.
2023 Lexus RZ450e -66k
- 1128 Views
Last post by tryingbe
- 752 Views
Last post by mayorpeoria
- 10 Replies
- 3079 Views
Last post by vtl
- 525 Views
- 804 Views
Last post by Manning
