So I recently acquired a 1999 V70 T5 from a buddy for $300. It's a high mileage car but seems to have been looked after fairly well. I was under hood replacing the starter and noticed this little hose and what appears to be either a filter or some kind of check valve just lying on the fan shroud. Can anyone help with identifying it?
Thanks in advance.
Can anyone identify this part? Topic is solved
- olsdkoolzcar
- Year and Model: 1999 V70 T5
- Has thanked: 5 times
- Has thanked: 1611 times
- Been thanked: 4075 times
Look for a solenoid under the fan shroud with an open nipple. Its either an SAS solenoid vacuum line or a purge vacuum line.
Unless the PO capped off the other end , you will have a vacuum leak and unmetered air which will make for poor running.
- olsdkoolzcar
Bingo! If I'd have looked a bit more carefully at the vacuum tree I would have found it. I've got about 5 projects going on at once on this car so I've been kinda scatterbrained.
- 1480 Views
- 9 Replies
- 2192 Views
Last post by Sommerfeldt
- 2841 Views
Last post by Geno9707
- 732 Views
Last post by ken_f
- 9 Replies
- 2388 Views
Last post by dconklin
