Only Drained 90oz Of Coolant Topic is solved
Oka
- Year and Model: XC70, 2001
- Has thanked: 9 times
- Been thanked: 4 times
I opened the overflow cap, jacked up the front left side of my 01XC and drained out 90oz/2.7L coolant. What went wrong? In the process, I pressed the upper hose a few times.
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
- Has thanked: 2656 times
- Been thanked: 1248 times
Was the high/low reading on the expansion tank within range?
Oka
Nope. The reading was high, because I filled the tank after replacing the thermostat and coolant temperature sensor. I was trying to bleed out some possible air, but the tank level was still high as I poured it in initially, so, I drained the coolant to refill the coolant the 'right' way.
Thanks.
Oka
Oh ok, and nice to know.
To do a refill, I won't have to drain that, would I?
Thanks
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
i always used the bottom hose but then i noticed the plug on the radiator and use that, ive never used the drain on the left side (back) of the engine. i get around 5litres out but theres always abit left in the block..i think you have a blockage
2001 XC70 factory M58
2002 XC70 auto (parts car)
- Has thanked: 1505 times
- Been thanked: 3818 times
You should get at least 4 liters of coolant if you just open the radiator petcock or pull off the lower radiator hose. Something is wrong if it’s a lot less than that, you are short About one liter.
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 64 times
- Been thanked: 69 times
Lots of people swear by citric acid flushes. Citric acid is a common/readily available food chemical.
Were cooling system flushes (citric acid flushes to be specific) more commonly done, A larger purchase split among members (the old "group buy") could make sense. And yes, I'm that cheap.
Do a clear water rinse and see what you get.
Where on the left side (back) of the engine is the block drain? Is it designed to be usable or is it a seized, rusted mess?
Rear drain , technically right side of the engine, is on the water pipe
It’s a high quality brass fitting on the steel pipe. I have not had trouble releasing it cleanly
- 4169 Views
Last post by mf70
- 2121 Views
Last post by alschnertz
