99 V70R - lost reverse
- kklepack
- Year and Model: 2016 XC60
- Has thanked: 12 times
- Been thanked: 5 times
So today while backing it to the garage I LOST reverse. Car drives fine forward no issues. When I select R car does not move and I hear transmission wine, I did drain and fill ( 300 miles ago). Anything I can check or look for another trans?
- Has thanked: 2215 times
- Been thanked: 1853 times
Assuming being a 99 it has the 4 speed auto trans? Normally if the reverse stops working it is the start of the transmission failing.
Did you confirm the oil level when hot is correct?
- Has thanked: 1614 times
- Been thanked: 4078 times
I’ve got a decent 1998 4 speed already out over here in NY. I could get it as Far west as Buffalo in short order
- kklepack
Yes it is 4 speed. I did another drain and fill , took for 20min drive. Checked fluid level while car was dunning and level is between low and hi but closer to low so I will add a little.scot850 wrote: 20 Sep 2020, 23:08 Assuming being a 99 it has the 4 speed auto trans? Normally if the reverse stops working it is the start of the transmission failing.
I wish yo a lot of luck!
- Been thanked: 504 times
When my 1998 GLT S70 lost an exhaust valve at 175K, I drove it (w the #3 injector d/c'd).
At 185K, I lost reverse. It was the final straw. Traded the car for $350. Bought a 2004 V70 w 100K...
- Clemens
- Has thanked: 501 times
- Been thanked: 228 times
I'd rather jump on Abscate's offer because it is known to be good.
But yes, 400 is alrightish, I guess.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
Give Erie VoVo a call and see what they ask.
It’s all in the logistics of shipping of course.
Mine is available vs the FDPP which is to say anything you care to pay gets donated back to board or if times are tight it’s a $0 item to you
Thanks for being a MVS Contributor here.
- 2104 Views
Last post by PeteB
- 10 Replies
- 946 Views
Last post by hharrell4th
- 1572 Views
Last post by bmdubya1198
- 9 Replies
- 3556 Views
Last post by KurtL
- 234 Views
